Old Sep 11, 2013, 12:55 AM
Australia, SA, Adelaide
Joined Jul 2013
Question
Is there a way to repair broken plastic sf props
Is there any way to repair broken plastic sf propellers?
RC Aerobat is offline Find More Posts by RC Aerobat
Old Sep 11, 2013, 07:39 AM
Thinking about flying
Rhea's Avatar
United States, MN, Eden Prairie
Joined Oct 2008
No!
Rhea is offline Find More Posts by Rhea
Old Sep 11, 2013, 09:45 AM
Redacted per NSA "suggestion"
dedStik's Avatar
United States, VA, Virginia Beach
Joined Feb 2012
Never ever ever ever attempt to repair a prop!
The only time I've messed with props, is reaming them to fit properly on a motor shaft, balancing them or shaving the ends down to fit another application.
A $7 prop is not worth repairing to risk the safety of those you fly near or the safety of property you fly around.
dedStik is offline Find More Posts by dedStik
Latest blog entry: More Confessions of a Smoker
Old Sep 11, 2013, 10:06 AM
Joined Jul 2013
It's just for the purpose of testing new designs in the front yard that are likely to crash and break straight away.
Old Sep 11, 2013, 12:02 PM
Rhea's Avatar
Joined Oct 2008
Still NO!!!
Old Sep 11, 2013, 02:37 PM
dedStik's Avatar
Joined Feb 2012
There is rarely an application like that where you can't make use of a prop saver.
Old Sep 11, 2013, 09:10 PM
Joined Jul 2013
Yeah I'll have to get some, I have a couple but no screws.
Yes I just need to test planes in the front garden before I put a proper prop on, of course I don't start the motor until I'm out of the plane of the prop spin and there is no one else there.
Old Sep 11, 2013, 09:33 PM
Joensuu, Finland
Joined Mar 2002
Even if there is nobody around, a repaired prop will fail and the remaining unbalanced mess will bend motor shaft and destroy any structures the motor is attached to.
Never ever ever ever attempt to repair a prop. For any reason.
jkettu is offline Find More Posts by jkettu
Old Sep 11, 2013, 10:03 PM
Joined Jul 2013
oh well better get some prop savers.
Old Sep 19, 2013, 09:29 AM
JudahBenHur's Avatar
Joined Sep 2012
A repaired prop is a ticking time bomb just waiting to take someones eye out. You know damn well that the repaired one that is only used to "test things" out in the back yard will be grabbed from the prop box at some point in time. It's time to retire it either by chucking it in the trash or use the broken pieces to mix up epoxy.
JudahBenHur is offline Find More Posts by JudahBenHur
Old Sep 19, 2013, 01:40 PM
dedStik's Avatar
Joined Feb 2012
+++ This
I rarely chuck them, I find alternate non-prop uses like mixing epoxy, or using them as paddles to flatten windings on motors.
Old Sep 23, 2013, 02:41 AM
Joined Jul 2013
It's fine, I bought lots of diffferent 10 packs of prop savers for all sizes.
No I was actually only wanting to use it for testing, I was building a scratchbuild and testing it with a powered glide test in the frontyard with various changes and it kept breaking the prop.
Anyway with the prop savers they shouldn't break aymore, I also bought quite a few packs of low cost props.
Anyway I've already chucked all the broken props.
Old Sep 24, 2013, 10:22 AM
dedStik's Avatar
Joined Feb 2012
I've broken two or three props while using prop savers, mostly when the plane lawn darted into the ground from over 75 feet.
Old Sep 25, 2013, 12:09 AM
Joined Jul 2013
Actually I got some motors with screw shafts that can't take prop savers but they are for existing planes that fly well already. Where I need them is for scratchbuild planes that I have to test and other planes after I have made mods to.
Old Oct 01, 2013, 12:13 PM
Neophyte hacker
portablevcb's Avatar
Albuquerque, NM USA
Joined Sep 2003
That seems like a good place to use propsavers, probably the only time I would use them. I really dislike the stupid things
portablevcb is offline Find More Posts by portablevcb
Discussion Plastic Prop repair with CA glue work? rswails Micro Ready-to-Fly 17 Jul 11, 2013 01:34 AM
Discussion Repair broken prop? hackdroot Giant Electric Planes 20 Apr 11, 2013 05:04 AM
Discussion what's the best way to repair plastic canopy? JCFLYR Crash Discussion 0 Mar 26, 2010 12:20 AM
Best way to repair a broken balsa wood motor mount??? rcwyant Parkflyers 13 Jul 30, 2003 09:13 AM
Best way to repair broken GWS motor mount? lensrc Foamies (Kits) 3 Aug 31, 2002 12:14 AM
