Old Oct 06, 2012, 07:30 PM
Manila, Philippines
Joined Jul 2001
Jpower A10
Got the jpower A10 and will be using an external bec. Can anybody post pics of their wiring set up using 2 ESCs and 1 lipo pack? Thanks.
Gerry Santos is offline Find More Posts by Gerry Santos
Old Oct 06, 2012, 09:20 PM
that's gonna leave a scar
KCinNC's Avatar
United States, NC, Mooresville
Joined Aug 2007
look up member "Joe 1320 "... he knows alot about the JPower A10's
KCinNC is offline Find More Posts by KCinNC
Old Oct 08, 2012, 11:32 AM
Joe 1320's Avatar
United States, FL, Sebring
Joined Feb 2006
here is a quickie hand drawing. One thing of note, you must remove the red wire in the servo leads coming from the ESCs. That is the positive lead that powers the ESC when you aren't using a seperate BEC. On my A-10, I took the positive and negative main power leads and Y'd them about an inch after the ESC. I then ran a main power plus and minus lead up to the battery compartment. The servo leads were cut about two inches from the ESC and Y'd together. I actually did all three at this point, I pulled the red wire from the final servo connector as it plugs into the receiver. As long as the red wire does not ultimately make it to the receiver, it doesn't really matter where you cut it and shrink wrap it. The external BEC positive and negative wires are soldered to the end of the main power leads right where the plug to receive the battery is soldered. The three wire servo lead coming from the BEC goes to an empty channel in the receiver. Some receivers actually show a dedicated "batt" port for just such a purpose.
Joe 1320 is offline Find More Posts by Joe 1320
Old Oct 08, 2012, 06:17 PM
Manila, Philippines
Joined Jul 2001
Thanks Joe. That was simple enough.
For Sale Skyangel/JPower 35mm EDF Jet Nano A10 Warthog PNP hobbyeasy Aircraft - Electric - Jets (FS/W) 0 Jan 04, 2012 10:04 AM
Discussion watt meter and A10 burnt speed controls (pic A10) steve ypsi mi GWS (Grand Wing Servo) 17 Apr 02, 2006 03:37 PM
Maiden A10, Another A10 Stock fly's great! (video) The Sarge GWS (Grand Wing Servo) 14 Aug 15, 2005 04:56 PM
EJF Mini A10 or DareDesign A10?? TeamSlacker Electric Ducted Fan Jet Talk 2 Sep 19, 2001 10:07 PM
