Old Sep 28, 2012, 01:16 AM
United States, CA, Santa Monica
Joined Jul 2011
Multirotor motors around $15
Tried the NTMs, but using the reverse shaft mount was just not good. The quality control is very bad and I get vibration whenever I fly. I still do not know how to reverse the motor on the NTMs- if anyone has instructions I would appreciate it. I'm outgrowing the DT750s and would like to try some other 750 kV motors that aren't ridiculously expensive $30 each. Any suggestions?
Lpbug is offline Find More Posts by Lpbug
Old Sep 28, 2012, 03:56 AM
What's a servo?
Australia, QLD, Brisbane
Joined Nov 2008
Sunnysky
Sad Sack is offline Find More Posts by Sad Sack
Old Sep 28, 2012, 04:12 AM
Hong Kong
Joined Sep 2004
Another vote for Sunnysky x2212 980kv..........
dtm360 is online now Find More Posts by dtm360
Old Sep 28, 2012, 04:14 AM
Hong Kong
Joined Sep 2004
For 750 kv..... Try AX2810....... But you do realize you will have to go to 4s?
Old Sep 28, 2012, 04:52 AM
gitit20's Avatar
Joined May 2012
YES i love the SS 2212 980KV great little motors..
gitit20 is offline Find More Posts by gitit20
Old Sep 28, 2012, 08:41 AM
Ungifted Prodigy
Multor's Avatar
Australia, QLD
Joined Jul 2012
reverse direction? swap 2 of the 3 motor wires?
Multor is offline Find More Posts by Multor
Old Sep 28, 2012, 06:58 PM
Joined Jul 2011
@ Mike, dtm and git: Thanks for the suggestion- I will try to find them although I might have to prop down (11*4.7) with 750 kv atm if I do end up using those motors.
Multor: I'm referring to the direction of the shaft, not the way it's spinning. Thanks for the advice anyway.
Old Sep 28, 2012, 07:02 PM
Joined Jul 2011
4s was overkill for my application since I am running 1147 props. Thanks for the tip though.
Old Sep 28, 2012, 07:40 PM
VA
Joined Nov 2009
Ken sells these at quadroufo. Use them on the quads I don't want to spend a ton of money in but still lift about 1.2kg on 3s. They are similar to rctimer so you may get a bad one every now and then but for $12 each and here in the states I don't know of anything cheaper.
http://www.quadroufo.com/product_inf...b1rk53h152pp04
pug398 is offline Find More Posts by pug398
Old Sep 29, 2012, 04:08 AM
koolkiwikat's Avatar
New Zealand, Auckland, Waitakere
Joined Sep 2007
Sunnysky x2212 980kv all the way, I have about 18 of them in use!
koolkiwikat is offline Find More Posts by koolkiwikat
Old Sep 29, 2012, 04:25 AM
Bitten by the RC Bug....
vineet_p's Avatar
India, Andhra Pradesh, Hyderabad
Joined Aug 2011
A friend of mine told he DID reverse the shaft.
He said he just undid the grub screw at the shaft and removed the C-clip with care, hit on the shaft with a hammer slightly to drive it towards the opposite end, then inserted the C-clip back and tightened the grub screw back in place.
I have 4 NTMs but never tried it.
And I guess I vote for sunnysky too. If you're gonna buy those sunnyskys, DO NOT buy from goodluckbuy. Go to HiModel.com instead.
vineet_p is offline Find More Posts by vineet_p
Old Sep 29, 2012, 06:11 PM
gitit20's Avatar
Joined May 2012
Yes some motors you can reverse the shaft I have the sunnysky motors 980KV with out a shaft sticking out either side just using the bolt on prop adapter. much better then the clamp kind IMO you can also get the same motor with a shaft and you can place it sticking out the top or bottom
Old Oct 02, 2012, 06:29 PM
Joined Jul 2011
Did he have to dremel his own C-clip slot?
Old Oct 03, 2012, 05:18 AM
vineet_p's Avatar
Joined Aug 2011
No, AFAIK nothing like drill, dremel or sort of. He said he just 'removed the C-clip and put it back'.
Old Oct 05, 2012, 05:49 PM
gitit20's Avatar
Joined May 2012
Yes a lot of the motors will have a set screw on the drum side and the shaft will have 2 slits for the c clip so that you can reverse it...
Wanted 370 motor (around 1000Kv) bryuly Aircraft - Electric - Power Systems (FS/W) 0 Apr 05, 2012 12:38 PM
Discussion I have a huge 12s motor laying around inrunner sherlockshah Pusher Prop Jet Models 2 Mar 25, 2012 07:51 AM
Discussion T-Motor MT series - Interesting new multirotor specific motors SebastianJ Multirotor Talk 26 Mar 16, 2012 03:52 PM
Cool Upgrade your nano/micro Multirotor 10g motors to Park 250 motors! daign Multirotor Talk 13 Jan 17, 2012 05:42 PM
