Old Jul 16, 2012, 05:00 PM
Atomic Playboy
United States, MN, Inver Grove Heights
Joined Jun 2012
Any way to get PPM Sum from a Turnigy 9x receiver?
I just got my 9x. I wasn't aware that the receivers for them don't output a PPM sum. It looks like there is a 6-channel receiver that outputs PPM sum and works with the 9x from HobbyKing, but people are complaining that the new version has removed this functionality. They didn't change the model number when they removed the functionality.
Shouldn't there be a solder point somewhere inside the receiver that I can pull a PPM sum from?
Had I known this was the case, I would have gotten the FlySky, but I thought all of these and the clones were the same. Now I know that's not the case. The FlySky has PPM sum receivers, and telemetry.
signal15 is offline Find More Posts by signal15
Old Jul 16, 2012, 11:17 PM
slebetman's Avatar
Malaysia, Selangor, Kajang
Joined Jun 2009
You mean the FrSky don't you? The 9x is a re-branded FlySky.
slebetman is offline Find More Posts by slebetman
Old Jul 17, 2012, 12:25 AM
Atomic Playboy
Joined Jun 2012
Doh. Yep. I was under the impression that the FlySky had telemetry. After further research, I found that you only get that with the FrSky mod to the 9x or the clones.
The parts are cheap enough, $15 for the DIY module. And there's a huge range of receivers instead of just the 2 that I can find that work with a stock 9x.
Old Jul 17, 2012, 12:42 AM
slebetman's Avatar
Joined Jun 2009
The stock 9x can work with 3 recievers. The 8 channel 9x receiver. The 6 channel T6A receiver and the 3 channel GT2 receiver.
But yes, the consensus seems to be that the FrSky system is better for not much extra cost.
Discussion Any plans to support PPM sum on the OSD PRO? IceWind Eagle Tree Systems 70 Jul 11, 2012 09:07 AM
Help! ASSAN 2.4 SUM PPM and muiltiwii(quadrino) shultz Multirotor Talk 3 Jun 10, 2012 12:27 PM
Discussion Arducopter and ppm sum receiver? igc23 Multirotor Talk 5 Sep 06, 2011 04:03 PM
Discussion Turnigy 9X 8C v2 receiver ppm signal freedom2000 Radios 6 Apr 08, 2011 08:43 AM
Discussion Getting PPM output from a Spektrum RX without any PPM stage Arthur P. DIY Electronics 44 Apr 26, 2010 04:38 AM
