Old Jan 16, 2011, 01:49 PM
Chris R
United Kingdom
Joined Dec 2009
Wing or glider?
Which one would be idea for getting very high up?
Im thinking 3000m+
Cir2kuk is offline Find More Posts by Cir2kuk
Old Jan 16, 2011, 09:16 PM
KC9TPL- Get Legit
BloomingtonFPV's Avatar
USA, IN, Bloomington
Joined Aug 2007
Search for Bracky72:
http://www.rcgroups.com/forums/showthread.php?t=1153401
He has an 11,000+ ft flight with a stryker
BloomingtonFPV is offline Find More Posts by BloomingtonFPV
Old Jan 16, 2011, 10:01 PM
Ochroma Lagopus Tekton
Fly Wheel's Avatar
Blackstock, South Carolina
Joined Sep 2007
What kind of TX/RX combo will give that kind of range?
Fly Wheel is offline Find More Posts by Fly Wheel
Old Jan 16, 2011, 11:08 PM
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Many of them will. THat is just over 2 miles. Many tx/rxs can easily acheive that.
BUT if I had to guess Bracky was using a Lawmate 2.4 ghz 500 mw TX and Lawmate Rx, since that was what was on his build log for his Stryker.
Derek_S is offline Find More Posts by Derek_S
Latest blog entry: Iconic X
Old Jan 16, 2011, 11:40 PM
wallaguest1's Avatar
Joined Nov 2006
if a stryker can, i guess a skyfun or funjet can reach 3000 too,
there is a video of Alejandro Villa with a maxi swift going up to 2300m, so maxi swift looks capable for this too,
wallaguest1 is offline Find More Posts by wallaguest1
Old Jan 17, 2011, 02:02 AM
Old Blighty
Joined Apr 2010
Multiplex Cularis @ 5000m
Flying Paul meets FPV Teil 1 (FPV High Altitude 15000 feet / 5 km) (8 min 2 sec)
Ian Davidson is offline Find More Posts by Ian Davidson
Old Jan 17, 2011, 02:38 AM
Chris R
United Kingdom
Joined Dec 2009
My current FPV platform is a Maxi Swift, i take it prop size has a say on max altitude?
Old Jan 17, 2011, 02:51 AM
Old Blighty
Joined Apr 2010
The post below is semi-relevant to this thread.
http://www.rcgroups.com/forums/showp...7&postcount=58
Old Jan 17, 2011, 03:02 AM
Chris R
United Kingdom
Joined Dec 2009
Ian your saying you have 3/4 the thrust + 3/4 the lift at 11,000ft? roughly!
Taking this into consideration when working out if you have enough power to reach that high.
Old Jan 17, 2011, 03:11 AM
Old Blighty
Joined Apr 2010
Indeed. The density of air at 10,000ft is only 74% of what it is at sea-level.
As a result, you'll only get 74% of the max thrust from the prop, 74% of the lift generated by the wings and all powered by a battery with probably a far lesser percentage of its capacity left.
Old Jan 17, 2011, 03:17 AM
Chris R
United Kingdom
Joined Dec 2009
I try to keep 1:1 power to weight ratio
1.0kg maxi swift + 25% more weight to make up for less lift = 1.25kg
So would need about 1.5kg+ of thrust to make it too 10,000ft.
Old Jan 17, 2011, 03:25 AM
Old Blighty
Joined Apr 2010
My Easy Star reached 8900ft with only a 200W motor and a 0.75 thrust/weight ratio, so you should have plenty of grunt with your set-up. That said, it took me AGES to get up to that altitude, so you should scale it far faster.
Old Jan 17, 2011, 03:33 AM
Chris R
United Kingdom
Joined Dec 2009
Pretty sure i have plenty power to get there!! still testing my rc+vtx range
Gonna try for 5000ft first and go from there, cheers for your help.
Old Jan 17, 2011, 03:45 AM
Old Blighty
Joined Apr 2010
Cool - look forward to hearing how you get on!
Old Jan 17, 2011, 03:07 PM
Zen09's Avatar
Germany, HB, Bremen
Joined Jun 2010
Yes but you have to consider the drag is also smaller
Zen09 is offline Find More Posts by Zen09
Discussion It Shouldn't Fly! $6 - 48" Power or Glider Wing tiretrax Flying Wings 109 Mar 31, 2014 11:01 PM
Mini-Speed Wing or similar as a glider? BrianRickman Foamies (Kits) 13 Jun 12, 2010 02:40 AM
Discussion Which should glide/thermal longer? Flying Wing or reg style glider? GreenAce92 Sailplane Talk 48 Feb 27, 2009 12:08 AM
Zagi THL or Zagi LE or any other epp wing glider Nik-rc Aircraft - Sailplanes (FS/W) 3 Jun 12, 2003 10:28 PM
WTB: Zagi THL or Zagi LE or any other epp wing glider Nik-rc Aircraft - Electric - Airplanes (FS/W) 3 Jun 07, 2003 03:04 PM
