Old Sep 05, 2005, 03:10 PM
It's a spiderweb of knit lines
Souderton Pa. USA
Joined Mar 2002
Molded Brushless Micro Motor
Hi All,
I've finally found the time to test mold a motor. I still need to make the front bearing carrier so the rotor is just in for show, no performance measurements yet. Here's some pictures.
mcross is offline Find More Posts by mcross
Old Sep 05, 2005, 03:31 PM
United Kingdom, England, Surrey
Joined Aug 2002
Amazing work. What type of bearings are you using in such a small motor?
Joe
devmonkey is offline Find More Posts by devmonkey
Old Sep 05, 2005, 03:37 PM
Souderton Pa. USA
Joined Mar 2002
Hi Joe,
There are many bearing options available to me. I could do ball bearings all around but it isn't really cost or weight effective. Oil impreginated bronze is best (my opinion) brass is next choice. This mold was made for brass so that's what this will get.
Old Sep 05, 2005, 03:42 PM
What goes up must come down..
Canada, QC, Saint-Laurent
Joined Jan 2002
Way to go Mike good show!
Please give us more info when you can interesting project!
Roger
rodair is offline Find More Posts by rodair
Old Sep 05, 2005, 06:08 PM
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
What have you used as the laminate around the coil there Mike?
NitroCharged is offline Find More Posts by NitroCharged
Old Sep 05, 2005, 07:13 PM
Joined Jan 2002
The lenght of it...? If you could move them more to the front?
just an idea here since we do not have a full pic...
Roger
Old Sep 05, 2005, 07:26 PM
Souderton Pa. USA
Joined Mar 2002
Hi Guys,
This one has ring laminations unlike previous versions I have made. I had to grind them to size and they are shorted on the outside, inside is good. I'll have to wait till I run it to see how good it works. If the shorting on the outside is a problem it can be sanded to eliminate the problem. There are better ring materials and other ways besides rings but performance costs! This is what I can afford, for now.
Length on the next one I make will be shorter, I had to "pull" the stack back a little cause I skimped on the insulation and a phase was shorting to the stack. As it is it withstands 500 VAC Hi-pot test. Also the circuit board is about 1.5mm too far back. I hope to get it down to 7 x 14 mm.
Old Sep 05, 2005, 08:08 PM
Joined Jan 2002
Mike, take care, you are reinventing the wheel for crying sick!
good luck with the sanding to get this one out! tolerances goes with patience...
Roger and out
Old Sep 05, 2005, 10:05 PM
Souderton Pa. USA
Joined Mar 2002
Hi Roger,
Sanding isn't really that hard at all, it's just to remove the smear from not having the correct grinding wheel. I probably won't even need to do it, the flux is very well contained within the stack, only a very slight attraction to metal outside the motor.
Old Sep 05, 2005, 11:21 PM
Joined Jan 2002
Mike,
maybe I am all wrong, I know it's very hard to keep all things all into a center to center where gaps are playing a major role. wish you good luck with all my hearth.
sheez, I need my glasses, you make me older, i would like to have this kind of enthouasiasm once more!
Very nice Mike once again.
Roger
Old Sep 06, 2005, 12:57 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
what gauge wire did you use? How many turns?
Old Sep 06, 2005, 06:26 AM
Souderton Pa. USA
Joined Mar 2002
This one is a very high KV motor. It's 10 turns of 32. Should draw about 1 amp on a single cell at DF speeds. A motor twice as long works very well DD with a GWS 2510, but will weight twice as much.
Note that this stye of motor is very different from outrunners and slotted motors, it turns way faster for the same number of turns.
Old Sep 06, 2005, 06:36 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
cool.
I'll be trying my hand at this shortly - just gotta get my workshop refit completed so I can get into all my projects that have been shelved during this time.
Old Sep 06, 2005, 09:23 AM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
sounds like a mini fiago it'll be sweet. micro ducted fans would sound really cool at that scale
Derrik
derk is offline Find More Posts by derk
Old Sep 06, 2005, 09:35 PM
Souderton Pa. USA
Joined Mar 2002
Front bearing holder picture.
For Sale Razor RZ-H2 brushless micro heli motor. King_Ice_Flash Aircraft - Electric - Power Systems (FS/W) 1 Jan 17, 2006 10:08 AM
NIB Century Lightning Brushless micro helicopter motor Bud Morrison Aircraft - Electric - Helis (FS/W) 0 Oct 16, 2004 02:43 PM
twin brushless 020 motor question mndbndr3d Electric Plane Talk 1 Sep 19, 2001 09:15 AM
pc sim/micro rec/micro motor/box combo--4 sale foss1997 Aircraft - Electric - Airplanes (FS/W) 0 Aug 08, 2001 12:59 AM
BRUSHLESS 10W MOTOR AIR MOVER Parkflyers 2 Jun 30, 2001 05:40 PM
