Old Oct 10, 2014, 07:02 PM
Aurora 9
Joined Jul 2014
Help!
Skyclimber problem
Hello,
I went to fly my Skyclimber today, at some moment I couldn't control on it for a few seconds, the ESC was beeping when it happened.
when the ESC stopped beeping, I could control it again and the motor was really weak.
it has a 20AMP ESC (stock), I have a Sawna SD-10G TX and RX600 RX.
I'm not sure what exactly the problem is.. I've checked the battery and it's alright, was full. tried another battery too and same issue.
Skyclimber beeping problem (0 min 56 sec)
I've recorded a video of the problem here, you can hear the beep twince, once when it falls off and once when it goes in the tree - and survived.
I really need your help.
tomer568 is offline Find More Posts by tomer568
Old Oct 11, 2014, 06:16 AM
Australia, NSW, Central Coast
Joined May 2014
How long were you flying for before it happened? Also how much was left on the battery when you tested it after the crash? You said in the video that the motor was really weak when you were trying to get it back. The motor will lose power first if the battery is very low.
Weird that it beeped and all control was lost though, range check was fine?
The beeps were different, the beep after the crash sounded a lot like an ESC arming.
craigfoot is offline Find More Posts by craigfoot
Old Oct 13, 2014, 11:37 AM
Aurora 9
Joined Jul 2014
5 minutes, almost full battery.
range check is fine
Help! Skyclimber problem tomer568 Power Systems 3 Oct 11, 2014 08:45 AM
Help! Skyclimber problem tomer568 Electric Sailplanes 0 Oct 10, 2014 06:48 PM
Discussion SkyClimber hoppy Electric Sailplanes 0 Aug 12, 2012 04:34 PM
Mini-Review Skyclimber 2 meter sailplane from Hobby King zen@lanset.com Electric Sailplanes 19 Jun 23, 2012 12:37 AM
