Old Dec 09, 2013, 10:50 PM
United States, IL, Monticello
Joined Sep 2013
Self-centering hinge for micro actuator
I was wondering what the best lightweight material to use for hinges on a 1/16" thick balsa rudder is. My hinges work now but when not being engaged by the actuator it's kind of floppy.
JT
AlmondBark is offline Find More Posts by AlmondBark
Old Dec 09, 2013, 11:43 PM
Power Wheels Guru
UNGN's Avatar
Southlake, TX
3.5" floppy disk material (mylar) is self centering, but is very low resistance if you use multiple thin strips.
UNGN is offline Find More Posts by UNGN
Old Dec 10, 2013, 03:41 AM
Weltherrschaft will be mine
Germany, SN, Leipzig
Joined Nov 2012
vhs tape is the same mterial as floppy discs, but thinner and already comes in a usable form.... I used to use it, but now I use only vhs tape, easier to work with.
just slit in the parts u want to connect, apply foam safe ca, put in one piece of tape, leave a gap of 1-3mm and let it cure between some books.
I really came to love vhs lately, one 90ties porno last for a life time of hinging material
borkencorter is offline Find More Posts by borkencorter
Old Dec 10, 2013, 03:54 AM
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
the floppy disk material is better for actuators than vhs tape, the vhs tape would be too loose. the tape would work better for servo models.
derk is offline Find More Posts by derk
Old Dec 10, 2013, 04:05 AM
Joined Oct 2006
Can U Not Use A Sm Centering Mag. On Ur Setup?
beastII is offline Find More Posts by beastII
Old Dec 10, 2013, 04:07 AM
Joined Nov 2012
have to admit, I only have two actuator models..... but on both of them the tape does a good job, but I hinge the whole surface instead of strips. in fact it makes a nice click when centering...
Old Dec 10, 2013, 07:39 AM
Gary
gklein's Avatar
USA, CT, Sandy Hook
Joined Dec 2009
No question - floppy disk material. The ability to vary the centering force by the width of your hinges is perfect.
gklein is offline Find More Posts by gklein
Old Dec 10, 2013, 08:24 AM
Joined Sep 2013
Thanks for the ideas. How would I go about using a magnet to provide centering?
JT
Old Dec 10, 2013, 01:25 PM
Joined Sep 2013
Also, is there a way to make an actuator stronger without making a new bigger one? Maybe making the magnet bigger?
Old Dec 10, 2013, 03:51 PM
United States, NY, Scarsdale
Joined Oct 2013
People use to use short lengths of rubber band for this.
August
K5083 is offline Find More Posts by K5083
Old Dec 10, 2013, 04:21 PM
Vince Herman's Avatar
United States, OH, Strongsville
Joined Nov 2000
JT
The little magnet pulls the actuator to the centered position when there is no input to the coil.
Vince Herman is offline Find More Posts by Vince Herman
Old Dec 12, 2013, 05:14 PM
Blackfw190's Avatar
United States, WA, Newcastle
Joined Aug 2011
Makes your aircraft that much more sexy, LOL
Blackfw190 is offline Find More Posts by Blackfw190
Idea Need help with Simple Self Centering Circuit For Blade MSR Servo dafremen Coaxial Helicopters 4 Aug 19, 2011 03:22 AM
Found Hinged Actuator for Butterfly termite Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 May 20, 2008 12:39 PM
Question Hinge material for smaller in-surface actuators? iter Scratchbuilt Indoor and Micro Models 27 Aug 19, 2006 09:54 AM
Discussion Hinging of reynolds covered for pager actuator mrfliboy Scratchbuilt Indoor and Micro Models 1 Feb 01, 2006 11:34 AM
