Old Aug 19, 2013, 06:33 PM
United States, OH, Cleveland
Joined Aug 2002
Best 2k paint on FMA and 770NC in Mold?
What it says, Concerned about solvent/reducer effect on 770.
I am looking for clear coat.
How about Urethane?
JIM CALDWELLA is offline Find More Posts by JIM CALDWELLA
Old Aug 20, 2013, 08:25 AM
Whisper Model Aircraft
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Ppg shop line 2k clear works good. I'd reduce it sometimes 100%
heliwill10 is offline Find More Posts by heliwill10
Old Aug 22, 2013, 12:19 AM
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
PPG Shop Line has line of 11 clear coats.
They differ one from the other like days and nights.
Which one do You use ?
And usually ,if You spray the molds with 2k clear ,DRY it and then do Your lay up
as a result You can have de-lamination between clear and cloth.
Dry clears does not like to stick to anything ,even to epoxy .It acts more like mylar.
UNLESS it is special clear .
Yuri
Dbox is online now Find More Posts by Dbox
Old Aug 22, 2013, 08:37 AM
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Here be the numbers... It will also work just fine with pro-set epoxy. Never had and bonding issues.
http://www.rcgroups.com/forums/showp...4&postcount=45
Discussion What kind of paint do you use on molded repairs if any? burke757 Multi Task F3X 11 Jul 18, 2013 09:51 PM
Discussion 2K paint klhoard Composites Fabrication 9 Feb 15, 2013 04:21 PM
Question Best mold construction method for Painting in the mold ScorpionRacing Composites Fabrication 3 Jan 14, 2011 03:28 PM
Question 2k paint properties for spraying into molds jirvin_4505 Composites Fabrication 22 Jan 18, 2009 01:58 PM
What 2k paint to use in molding? sayno2glo High Performance 49 Aug 20, 2005 04:34 PM
