Old Dec 11, 2014, 06:42 PM
Tomkfly's Avatar
United Kingdom, England, Birkenhead
Joined Jan 2013
Well I guess I must have started with V1.37, but of course I would have just started to feel my way, so never got to look at the expos/dual tab, so that is probably why I can't remember it. I do qremember the first setup I did was for a P51D and I spent a bit of time sorting out a gear door sequencer.
Tom
Tomkfly is offline Find More Posts by Tomkfly
Old Dec 12, 2014, 08:40 AM
Italy, Lazio, Pomezia
Joined Mar 2014
Originally Posted by Tomkfly View Post
Try as Nigel suggests and uninstall the drivers. reboot the PC and then try again.
If that doesn't work You may have to go the Zadig Route,
But first try, even if you have already done the following.
Check your drives, when connected by USB, and see if there are any extra drives showing. If nothing shows there then, with the TX switched off open device manager connect the USB and see if anything changes when you connect and disconnect the TX. Then do the same with the TX switched on and then again with the TX switched on using the 3 finger method.
A daft question: I assume you do have OpenTX Companion V2.x. xx loaded on your PC?
Tom
ok, I've followed your inputs on two different PCs using Win7 and on one PC using ubuntu 14.04 and on my android 4.2 tab....
on win7 and ubuntu I have companion 2.0.13
on taranis plus I have openTX 2.0.13
results are
- on android tab, only using the 3-finger method, I can see the two storages (EEPROM with EEPROM.BIN and FIRMWARE.BIN) and SD card
- on win7 and ubuntu PCs, NOTHING!!!!!
At the end I decided to set-up the radio directly on the radio without using the companion on which I only simulate the configs....
antpoli is offline Find More Posts by antpoli
Old Dec 12, 2014, 08:53 AM
yorkshire UK
Joined Oct 2007
results are
Have you intalled zadig at all yet?
It was a year or so ago I set my PC up so sorry not much help, scot or someone might help with screen share if you ask really nicely.
I set all my stuff on tx, only use PC to get updates and test out ideas, much easier to know if you are getting it right when you can see the servos moving.
nigelsheffield is offline Find More Posts by nigelsheffield
Old Dec 12, 2014, 09:00 AM
United States, OH, Cleveland
Joined Aug 2002
Why zadig with taranis plus???
JIM CALDWELLA is offline Find More Posts by JIM CALDWELLA
Old Dec 12, 2014, 09:34 AM
Joined Mar 2014
I've installed zadig as well, but no results due to the fact PC does not recognize the the radio
I will setup everything on the radio as well... but still my quad is under construction so cannot test motors yet
Old Dec 12, 2014, 09:37 AM
yorkshire UK
Joined Oct 2007
OK, zadig is still used to update if you want to update boot loader at same time.
Like I said it was over a year ago I did my Taranis install.
I think its a driver problem though as it works on his android devicemso nothing arong with the tx.
I would plug in tx switched off and uninstall drivers, maybe do same in bootloder.
Restart PC and try again, no zadig this time, just let the PC do its thing.
Sorry if you have already tried this.
Very frustrating I know!
Old Dec 12, 2014, 09:55 AM
Joined Mar 2014
tried almost everything. very very frustrating
Old Dec 12, 2014, 11:42 AM
United States, IA, Armstrong
Joined Jan 2014
You do not need to mess with Zadig with the Plus it already has the bootloader installed.This has been explained 4700 times before.
Cyjonz is online now Find More Posts by Cyjonz
Old Dec 12, 2014, 11:54 AM
The ground is the limit!
spooky_0325's Avatar
United Kingdom, Cannock
Joined Dec 2012
Sticker Bomb
Finished!
spooky_0325 is offline Find More Posts by spooky_0325
Old Dec 12, 2014, 12:00 PM
Joined Mar 2014
Originally Posted by spooky_0325 View Post
Finished!
cool
Old Dec 12, 2014, 01:23 PM
KC
Registered Loiterer.
KC's Avatar
United States, FL, Orlando
Joined Sep 2006
Picasso meets Austin Powers meets the Brady Bunch... A work of art!
KC is offline Find More Posts by KC
Old Dec 12, 2014, 04:18 PM
Tomkfly's Avatar
Joined Jan 2013
It looks like it is a problem with the USB driver on the PCs.
Is your PC showing an unknown device in USB Devices. If it is try doing a driver update on it.
Tom
Old Dec 12, 2014, 07:37 PM
Joined Dec 2012
Thanks Guys. I'm well happy with it. The case swap is an absolute doddle. The one that worried me was the screen. But, it pushed out no problem and the sticky that is all around the window adhered straight back onto the new case.
Happy Days!
Old Dec 13, 2014, 11:25 AM
Dreams are real to real
Loose, Kent. England
Joined May 2005
You would use the variable expo to determine what value you are comfortable with and then change the expo in the mix to that value. However, I only suggested it to show you the one of the capabilities of the Taranis.
Tom
And that's exactly how I am going to use your help!
Smiler is offline Find More Posts by Smiler
New Product FrSky Taranis - 16 Channels, Full Telemetry, RSSI Rotozuk Radios 38507 Yesterday 11:07 PM
Discussion Owner's Thread: ROC HOBBY 2.2M V-TAIL GLIDER by FMS/MOTIONRC StarHopper44 Electric Sailplanes 1828 Dec 13, 2014 11:22 PM
Question FrSky Taranis - assimilating web info mcshaz Radios 4 Nov 30, 2014 08:01 PM
Discussion is the FrSky Taranis next step after Turnigy 9X 9Ch tormodnt Radios 3 Nov 30, 2014 07:58 PM
