Old Jan 14, 2013, 10:39 PM
bluffman's Avatar
Joined Sep 2003
It's not that much work, just a little glass servos, oh a new nose and you are ready for paint, 3 days at your pace.
bluffman is offline Find More Posts by bluffman
Old Jan 16, 2013, 09:42 PM
Joined Sep 2005
Empire of the Sun is on! Zeros?
topazpilot is offline Find More Posts by topazpilot
Old Jan 17, 2013, 11:22 AM
Composites guy
North OC, Ca.
Joined Jun 2005
TFLG wrote "Seriously, like you don't think that thing is fixed already"
See, you are slowing down - you should have flown it already!
Oh wait, UPS sending the servos again? Never mind. He will probably have fit
full size servos in the mean time.
And there is an ISR build night tonight......
Production scale slope building - I like it!
Scott
sarmoby is offline Find More Posts by sarmoby
Old Jan 17, 2013, 11:35 AM
That Freeking Laird Guy
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
Scott
I do already have most of the damage fixed. Just need to fix the cosmetics now. Then I need to get a motor, servos, batteries etc.
TFLG is online now Find More Posts by TFLG
Old Jan 17, 2013, 12:32 PM
bluffman's Avatar
Joined Sep 2003
neu 1509 1.6 with 16/17 thin prop, 4200lipo 60c burst, it will be balstic,
Old Jan 18, 2013, 01:32 AM
kenracer759's Avatar
Lancaster Ca
Joined May 2008
Flight?
Does it fly or is it a poser ? Throw it and have fun.My race car aint pretty but 60 wins and two Wallies< a few Championships and its as UGLY as I...........................................Throw it .yes I'm Crunk
kenracer759 is offline Find More Posts by kenracer759
Old Jan 21, 2013, 05:23 PM
Joined Nov 2006
Which west systems glass do you use? epoxy or sanding resin or what?
also...
Is the fiberglass tape actually sticky so that you can get a smooth application...ie you just tape it down then glass it?
lastly...
where can you buy that stuff from a storefront?
I finished the wing on my BL p51 and am ready for the next step and I wasnt sure what to use...
cheers!
Troy "tbogey" Bogert
tbogey is offline Find More Posts by tbogey
Old Jan 21, 2013, 06:21 PM
TFLG's Avatar
Joined Feb 2002
also...
lastly...
cheers!
If you are talking about the glass for the bottom of the rudder you can just use CA (Thin) if you don't have resin. West systems will cost you a fortune. All I do is place a small bit of fiberglass cloth over the bottom of the rudder and onto the fuse an inch or two, then apply the resin or the CA.(what every you have laying around). Once it dries sand it a little and then put filler on it and sand it smooth (I use bondo). See attached plans
Old Jan 21, 2013, 07:09 PM
Joined Nov 2006
Thanks for the plans..they are basically the same as what you sent with the kit, if not the same.
Ill do that for the tail, but I was more thinking of the joining of the wings. I have some 5 minute epoxy but the directions call for glass. Would 10 minute epoxy work over the fiberglass or should that be proper fiberglass resin...I know i am probably overthinking this but I want to make it strong.
also, When you say "fiberglass tape" is that actually a type of tape as per my earlier question.
cheers and thanks for all the help...I hope to have her ready for the PSS fest in may.
Old Jan 21, 2013, 08:01 PM
TFLG's Avatar
Joined Feb 2002
For the wing, any fiberglass will work. Tape, cloth whatever. The more you put on the stronger the joint will be. 5 or 10 minute epoxy is probably too thick to wet out the cloth. 30 minute epoxy is thick too but it at least gives you enough time to wet the cloth. If you want to use 30 min epoxy, you put the epoxy on the wing, then lay the glass over that. Put some wax paper over it and then rub the cloth into the epoxy. Once it dries remove the wax paper.
Old Feb 02, 2013, 11:26 PM
Livin ...The Endless Summer
67econoline's Avatar
United States, CA, San Juan Capistrano
Joined May 2011
67econoline is offline Find More Posts by 67econoline
Old Feb 03, 2013, 01:48 AM
Dang!....What else did I bring
oletimer's Avatar
Orange County, S. Cal
Joined Oct 2009
Any Word Yet???
Have I missed something? or have we not given a ETA on the build days to pick up planes??? Thouht I saw something but don't see it here on the blog site.
Jeff
Who is almost done getting his ME-262 and will be very ready for a Zero!
oletimer is offline Find More Posts by oletimer
Old Feb 03, 2013, 10:25 AM
It's not going to build itself
TRISME's Avatar
Aliso Viejo,CA
Joined Aug 2005
Hey Jeff,
I think it was posted in the group build thread.
Tom
TRISME is offline Find More Posts by TRISME
Wanted Fuselage, large, scale, semi-scale for slope A10FLYR Aircraft - Sailplanes (FS/W) 5 Mar 12, 2012 01:58 PM
Wanted Slope Scale Hellcat or Zero Chickenfoot Aircraft - Sailplanes (FS/W) 0 Feb 04, 2007 01:48 AM
Mini-HowTo 40" Slope Scale Zero gavoss Slope 9 Aug 03, 2006 03:32 PM
Found slope scale zero fuse or full kit masson74 Aircraft - Sailplanes (FS/W) 4 Jul 25, 2006 01:34 AM
Sold RTF Slope Scale Zero surfimp Aircraft - Sailplanes (FS/W) 7 Feb 18, 2006 08:46 PM
