Old Dec 29, 2012, 04:23 PM
Joined Oct 2012
Idea
Using Foils4.2f to print out Fuselage Formers!
Hi again guys,
Something that has caught my interest is creating .DAT Files
for Fuselage Formers, since discovering that "Foils 4.2f" treats them
as Aerofoil coordinates.
Foils 4.2f also allows for sheeting and Leading and trailing edges.
If a former's flat and radiused at the bottom, it will put in
flat, bottom sheeting to any thickness you want - and a top sheet.
Using the Foam - cutting option, you can divide the Former into as
many sections as you want stringers, and print out the Formers to
any size you want, using the "Chord" as the height of your Former.
You can also alter the thickness of them and even create blended
Formers.
I've supplied some DAT Former Files I made up!
I hope you find them..and this info helpful!
Ian
IanVC is offline Find More Posts by IanVC
Mini-HowTo how to print out 1:1 3 view drawings for diy airframes nemoskull Scratchbuilt Indoor and Micro Models 17 Sep 06, 2012 11:06 AM
Help! Printing out plans torque roll Foamies (Scratchbuilt) 11 May 08, 2012 04:15 AM
Discussion Using CNC router table to cut out half of fuselage and wings videorov Foamies (Scratchbuilt) 9 Apr 04, 2012 08:18 PM
Discussion Anybody use Foils4.2f? GreenAce92 Sailplane Talk 2 Apr 18, 2010 02:35 PM
Pro Bond Anyone Used It To Install Formers In A Glass Fuselage? Joe Elston Electric Ducted Fan Jet Talk 10 Dec 24, 2002 07:00 AM
