Old Apr 06, 2012, 12:54 PM
Joined Jan 2012
Covering Barometer
Hi Everyone, Just wanted to know if anyone has covered there barometer from light sensitivity and how they did it. I heard some people using superglue to put on the foam. Sounds scary. Thanks Roman
rkenosha is offline Find More Posts by rkenosha
Old Apr 06, 2012, 01:44 PM
A man with too many toys
United States
Joined Feb 2001
I use a thin piece of low-density foam rubber to allow easy airflow (about 1/16” thick). I use canopy cement to attach it and make sure that I keep the cement far away from the sensor. I would not recommend CA. Canopy cement can be easily removed with out damage to the board and CA can not.
RC Man is offline Find More Posts by RC Man
Old Apr 06, 2012, 02:04 PM
United States, IL, Chicago
Joined Oct 2011
Hello,
We would never recommend glue of any sort, that just seems like a bad idea.
The cheap, simple, and safe way to go about this is to use a piece of small, airy foam and simply use masking tape, or scotch tape to hold this in place. Yes this does look kinda silly, but it works, and doesn't risk damaging or destroying your barometer.
The better way would be to simply secure your board in place with a case, and some foam between the top of the barometer and the case. Where might you get a case you ask?
If you have a green board, you can find this guy here selling ones for them.
http://www.rcgroups.com/forums/showthread.php?t=1623335
Otherwise, if you have the newer PRO board you can contact us, as we have a case for those. Pictures at the link below.
http://www.rcgroups.com/forums/showthread.php?t=1627541
MadLab is offline Find More Posts by MadLab
Latest blog entry: Hexapod Quadcopter
Old Apr 06, 2012, 02:30 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
I use the foam from the HoverFly packaging box.
I use double sided tape to keep it on
Adidas4275 is offline Find More Posts by Adidas4275
Old Apr 06, 2012, 10:07 PM
SuperX Hex and X8 Flyer
ross_badger's Avatar
Columbus, IN
Joined Jul 2009
Double-sided tape and a piece of foam as shown....
ross_badger is offline Find More Posts by ross_badger
Old Apr 28, 2014, 05:52 AM
Joined Mar 2014
Another example of covering it, and details of what can happen if you don't cover it properly:
http://purposefulscience.blogspot.co...of-ms5611.html
fliperbaker is offline Find More Posts by fliperbaker
For Sale It turns out that the 53 had a plain rocker cover and the 63 had a black rocker cover rpwarehime Aircraft - Fuel - Engines and Accessories (FS/W) 4 Apr 01, 2012 10:54 PM
Discussion MultiWii Barometer Fast reaction Jessestr Multirotor Talk 5 Mar 29, 2012 11:37 AM
For Sale Dragon osd current sensor, Barometer, GPS screwup FPV Equipment (FS/W) 0 Oct 10, 2011 07:34 AM
to cover my PBY Catalina or not to cover? jeff262 Waterplanes 5 May 02, 2005 12:02 AM
