Old Mar 31, 2011, 01:37 PM
My tapeworm tells me what todo
United States, TX, Houston
Joined Feb 2007
Dual gyros, flaperons arrrgggg
So I’m a cheap bastage and don’t want to upgrade my dx7.
Though now my skywalker has so many bells and whisles im trying to find ways to integrate items. So here we gooooooooooo...........................
I want to use flaperons instead of seperate flaps/alerons but I use a gy401 off my ailerons with a y harness currently. So going to flaperons I will have to eliminate the gyro I believe. As I will have 2 channels instead of one to run through the gyro.
Alas I have 2 elcheepo 12$ gyros that are tiny. Problem is they default to heading hold unless you plug in a separate wire to a switchable channel to change it to non HH mode.
So first question is: Does anyone know how to trick the gyro into thinking its getting the proper signal over the remote wire?
Second: anyone have another idea to solve this issue with a single gyro?
Don’t be capt obvious and say install flaps.
tconners is offline Find More Posts by tconners
Old Mar 31, 2011, 01:39 PM
Hugeone's Avatar
Canada,Quebec
Joined Jan 2005
1) use a V-tail mixer with one gyro.
2) use a GWS fail-safe (it generate a fixed signal, adjusted by a pot)
Hugeone is online now Find More Posts by Hugeone
Old Mar 31, 2011, 01:44 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Or buy a Futaba GYA351 airplane gyro which is single axis, but has two inputs/two outputs
so it works with flaperons/elevons/etc.. $135 though.
ian
Daemon is offline Find More Posts by Daemon
Old Mar 31, 2011, 09:08 PM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
just pick a wing and run that one by itself. ive seen that done by a lot of nitro pattern noobs that can't afford better over the years.
it works fine.
Toysrme is offline Find More Posts by Toysrme
Old Apr 01, 2011, 07:45 AM
techspy's Avatar
USA, NC, Matthews
Joined Aug 2008
FYI, I have used one gyro on one control surface before with no issues. I did this on a flying wing with elevons and on my skywalker, Works fine. As for the signal, maybe a $7 servo tester? Or, do you have any channel on the rx that never goes to the point that would put it in HH mode? if so, just tap into that signal.
techspy is online now Find More Posts by techspy
Latest blog entry: My Esprit Saga
Discussion Gyros on the Hawk Sky with DX6i dual aileron setup mamcrackin Electric Plane Talk 0 Feb 11, 2011 01:46 PM
Question Combination of dual rate and rate gyros CanadianEngineer Electric Plane Talk 3 Sep 23, 2010 08:26 PM
Question Dual-servo ailerons (flaperons) with a Berg 7P Spackles94 Radios 0 Feb 22, 2008 09:41 AM
Help! Esky honeybee cp2 arrrgggg!!!! sqito Micro Helis 13 Oct 23, 2006 12:42 PM
Reflex: Flaperons/ Dual Ailerons? steelgtr Simulators 1 Apr 08, 2005 12:28 PM
