Old Feb 01, 2013, 03:26 PM
wjjones's Avatar
Joined Jun 2001
Charge Rate for Hyp 320 battery
I have a Hyperion 2S 320 mah battery that I want to charge with my Bantam BC6DXII charger. When setting up the program, I have to choose between capacities of 300ma and 400ma--nothing in between.
Which setting would be best? If I choose the 300ma capacity would the battery get "filled" ? If I choose 400 would I damage the battery?
TIA
wjjones is offline Find More Posts by wjjones
Old Feb 01, 2013, 03:31 PM
United States, MN
Joined Feb 2011
Either is fine. That battery has a max 5C charge rate (double check that on the label), so anything under 1.6A will not damage it. Personally I would probably charge it at 700ma, but if you want to do closer to 1C go with 400ma.
grimbeaver is offline Find More Posts by grimbeaver
Question parkzone lipo max charge rate? duker733 Batteries and Chargers 15 Jun 26, 2013 07:00 PM
Discussion Optimum charge rate kallend Batteries and Chargers 20 Feb 04, 2013 10:44 PM
Discussion lipo charge rate Bernhard3 Batteries and Chargers 5 Jan 07, 2013 04:14 AM
Sold Hobby King Multi-battery charging adapter for UMX-type batteries K_B Aircraft - Electric - Batteries & Chargers (FS/W) 1 Jan 03, 2013 08:02 AM
Can the Hitec CG-320 charge the Zagi 400X 8 cell KR-1700AU battery NiMh pack? baconfingers Foamies (Kits) 0 Mar 24, 2002 02:47 PM
