Old Jul 03, 2009, 11:09 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
My GWS B2
A couple of days ago, while I was at the local hobby shop, I came across a slightly shelf worn box on clearance containing a GWS B2 bomber kit. Since it had the EDF units, I couldn't resist. So I bought it and proceeded to put it together.
I set it up to use a 800mah 2s1p Lipo pack instead of the Nicads and I used a heavier duty brushed ESC as it is like 110 degrees F out here right now and a smaller ESC may not be able to handle the heat. it has two 6g Spektrum Digital servos on the elevons and a Cox 6g servo on the nosewheel. I am using a Turnigy 9 channwl radio with 2.4ghz Assan TX and RX.
earlwb is online now Find More Posts by earlwb
Latest blog entry: My Low Wing plane
Old Jul 03, 2009, 11:28 PM
cant leave things stock
jstoll's Avatar
USA, CA, Santa Cruz
Joined Feb 2007
cool man hows it fly?
whats the wingspann & how big are the EDFs ? can you stuff bigger ones in there ?
take cre
JAK
jstoll is offline Find More Posts by jstoll
Old Jul 03, 2009, 11:44 PM
earlwb's Avatar
USA, TX, Grapevine
Joined Dec 2008
Don't know about how it flies yet. Still to be maidened.
39.5 inch wingspan.
It uses two 55mm GWS EDF fans. They have the stock brushed motors in it.
One could go with a pair of 55mm brushless units if they want to increase the power more. I am sure one could easily get a power gain over the cheap brush motors.
I should mention it is a discontinued kit. GWS quit making it.
Old Jan 28, 2014, 10:51 AM
Turbobearcat's Avatar
Joined Aug 2011
I know this is over 5 years old- just found the kit and bought it... I plan on using the 50mm and then try hiding those ugly holes under the wings!!!!
Turbobearcat is offline Find More Posts by Turbobearcat
Anyone got a good picture of the seats in a tigermoth to stick on my GWS chargin Parkflyers 1 Jan 12, 2002 11:16 PM
Question about my gws RX sventek1 Electric Plane Talk 4 Dec 03, 2001 08:33 AM
Swap: My GWS PICO-RX (JR) for a GWS PICO-RX (Futaba) pullin-gs Aircraft - Electric - Airplanes (FS/W) 3 Oct 23, 2001 08:03 PM
Gws B2? Mikey_Flies Parkflyers 14 Sep 16, 2001 11:25 PM
37 minutes flighrs with my GWS Pico J3-F Will Chapman Parkflyers 4 Jun 17, 2001 12:37 AM
