Old Jan 02, 2012, 03:33 PM
Gig 'Em!
TexasAggie's Avatar
United States, TX, College Station
Joined Nov 2010
The wire length he lists for 1280 (18.49"/469.8mm) and the quarter wavelength (2.31"/60mm) do not work out. He says the 60mm should be an eighth of the wire length. I'll try 235mm for each leaf (I was using 240, which the CL dimension) this time and see how that ends up.
TexasAggie is offline Find More Posts by TexasAggie
Old Jan 02, 2012, 03:43 PM
I think it'll work this time!!
Chairwolf's Avatar
399 feet above Roanoke, VA
Joined Jan 2007
Sounds good! I hope your trash can has less wire in it than mine!!
Chairwolf is offline Find More Posts by Chairwolf
Old Jan 02, 2012, 03:46 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Well I bought a 2lb spool of welding wire, so it has the potential to be stuffed...
Old Jan 02, 2012, 03:56 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Here's where the discrepancy exists: his quarter-wave metric calculations are screwy. 75168/1280 = 58.7 NOT 60. The lengths in his photos also don't agree with his computations.
Old Jan 02, 2012, 04:05 PM
Chairwolf's Avatar
Joined Jan 2007
Don't forget to add a little for the hooks and the tail on the ground side.
Old Jan 02, 2012, 04:07 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
I'm leaving the hooks off of this one, and the tails don't matter since they're attached when the center conductor is shielded.
Old Jan 02, 2012, 07:29 PM
Registered FPVer :)
markus123456's Avatar
Switzerland, LU, Buchrain
Joined Aug 2006
My first SPW attempt turned out pretty nicely. I'll put up pictures in a little while. One question: In the below video, the angles that are supposed to be about 17 degrees turned out to be about 40 degrees in mine. Is this okay or should I redo it?
40 degrees is a lot. Try it out. If they perform good enough for what you are after - who cares! If not, you found one point to improfe.
It seems like the relation of the arc length compared to the two legs is not ok then. Usually the arc should be about half the wafelength, the legs about a quarter. Note though that the correction factor to apply differs between the SPW and the CL antenna.
HTH
Markus
markus123456 is offline Find More Posts by markus123456
Old Jan 03, 2012, 09:39 AM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
TexasAggie - You might find the little hooks help a lot. They won't harm anything at 1.3GHz. I make them as long as the feedpoint gap so the overall lobe lenght is consistent.
The lobes should be .5% longer than 1 full wavelength depending on the wire thickness you use. Wire thickness will change resonant wavelength, so the little details will change. Generally the thicker the wire, the higher the resistance (I know this sounds backwards but we're talking RF, not DC). My calculations were done with .035" wire. if you use thinner wire (say .030 or .025) you will need the lobes to be slightly longer than my calculations.
-Alex
IBCrazy is offline Find More Posts by IBCrazy
Old Jan 03, 2012, 10:19 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
I've got .030 welding wire. So do I need to add the length of the hook to the lobe length, or get the lobes correct and then just bend the last few mm into the hook? Also, how important is that 105 angle? Without another dimension, I find that it can be physically anywhere in a fairly large range. Seems 115 gives a nice-looking lobe. That dashed line on the left is tangent to the arc at the corner.
Edit: I'm going to be doing the trick in your YouTube video with the legs, so I'll make 4 independent lobes.
Old Jan 03, 2012, 10:28 AM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Since you're here, Alex, can you take a quick look at my FPV test flight from yesterday and give any troubleshooting tips you can think of? 1280 MHz. Tx is a generic 400 mW from RMRC. Rx is Lawmate unmodified. Both antennas were cloverleafs. The transmitter antenna was slightly better-made than the receiver antenna. I highly doubt the problem is due to the Tx turning off in flight, since I replaced all my wiring.
www.youtube.com/watch?v=l7lb99DZL4I
Old Jan 03, 2012, 12:50 PM
Engineer for Christ
IBCrazy's Avatar
Amherst, VA
Joined Jun 2006
Texas Aggie - I bend my hooks after I strip the cable. The length of the hooks = feed gap length. The reason is that the feed gap counts as part of your lobe length. Therefore by bending the hooks in the end you remove that length from the lobe itself but it gets added back in the soldering stage due to the feed gap. If you had no feed gap at all you would need to add a little wire for your hooks.
The arc isn't too critical. Just be sure it doesn't touch the adjacent lobe.
When I look at your video, your problem appears to be external interference. Perhaps a pulsed transmission? I can't tell. Your video is rock solid and then suddenly loses the frame sync. This would indicate an outside source.
-Alex
Old Jan 03, 2012, 12:56 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
Thanks for the tips. I really appreciate your help. I'm kind of surprised at video interference since that park is basically in the middle of a forest with no built-up areas for several miles.
Also, when you say "slightly longer" for the .03 wire, can you quantify?
Old Jan 03, 2012, 01:44 PM
Nobert's Avatar
Tucson Avra Valley, Arizona, United States
Joined Jul 2002
TA
Here in Tucson the public services all use the 1280 band. They have a lot more power and can interfere with FPV setups.
Hope this helps.
Neal
Nobert is offline Find More Posts by Nobert
Old Jan 03, 2012, 01:50 PM
Gig 'Em!
TexasAggie's Avatar
Joined Nov 2010
How did you find this out?
Old Jan 03, 2012, 04:46 PM
Nobert's Avatar
Joined Jul 2002
I have friends in Police, Fire and EMT.
Neal
Discussion Left/Right circular polarized antenna ? SpookiePower FPV Talk 49 Oct 15, 2014 10:23 AM
Mini-HowTo DIY Ground Plane omni directional RX antenna IBCrazy FPV Talk 60 Nov 19, 2012 07:11 AM
Discussion 900 mhz circular polarized antenna? g00bd0g FPV Talk 9 Aug 21, 2012 10:54 AM
Discussion 18dbi Circular Polarized Patch ? Coyote64 FPV Talk 3 Nov 10, 2010 05:59 PM
Question Circular polarized antenna question Sov4life FPV Talk 8 Mar 05, 2010 06:00 PM
