Old Jul 17, 2006, 07:32 PM
CA's my friend's Avatar
Anthem,AZ
Joined Jun 2006
Help!
Cox Throttle Sleeves
will these fit the sure starts http://www.coxmodels.com/prodinfo.asp?number=C20468 thank you in advance my searches turned up nothing
cmf
CA's my friend is offline Find More Posts by CA's my friend
Old Jul 18, 2006, 07:43 AM
Concord,NC
Joined Sep 2003
I am afraid they won't, the cylinders that they fit have been ground on the o.d. so the sleeve will fit over it.
Later,
Tim
Tim Wiltse is offline Find More Posts by Tim Wiltse
Old Jul 19, 2006, 04:04 AM
QLD, Australia
Joined Sep 2003
To grind the cylinder to fit the sleeve is a simple job.
1/ get a peice of dowel and sand it so the sleeve fits ofer it firmly
2/ chuck the dowel with mounted sleeve in a lathe or drill
3/ hold a stone against the clylinder while it spins- check fit of the sleeve regularly, as soo as it almost fits on the cylinder stop with the stone and use bon ami to grind/hone the sleeve and cylinder to a neat fit.
clean the clylinder and sleeve, lightly oil and check for free rotation - it is important there is no exces slop as the sleeve will leak to much to give low throttle.
Only takes 10-15 mins to get a good fit.
Stewart
clipclop is offline Find More Posts by clipclop
Old Aug 06, 2006, 07:04 PM
"what ever just crash it"
luger007's Avatar
South Kingstown, RI
Joined Apr 2005
Another idea to make the throttle sleeve fit is to buy a used .049 off E-bay that the cylinder is already fitted for a sleeve. You an likely find a used engine off e-bay or this forum for about the same cost as the new sleeve. I think the RC Bee, Dragenfly, and Black Widdow all had cylinders that would fit the sleeve if I recall correctly. (been a while) Unless you already have the engine, from what I've read, the Norvel engines are better all around.
luger007 is online now Find More Posts by luger007
Old Sep 04, 2006, 04:46 PM
Beaver Dam.Wi.
Joined Jan 2003
cox .09 throttle sleeve. Where can I get one, does anyone custom make them?
Harris
harrisdouma is offline Find More Posts by harrisdouma
Old Oct 09, 2006, 12:01 AM
Burner!!
PlaneCrazee's Avatar
United States, AR, Little Rock
Joined Jun 2005
I picked up 3 cylinder/piston/rod sets for my Medalion .09 RC from Cox recently but they didn't com with the sleeves. If you can find the sleeve, I'll sell you one of the cylinder kits...
PlaneCrazee is offline Find More Posts by PlaneCrazee
Old Oct 09, 2006, 10:59 AM
Beaver Dam.Wi.
Joined Jan 2003
thanks for the offer plane crazee
Old Nov 18, 2006, 10:35 PM
Joined Sep 2006
Cox Product Throttle
Check this old thread at RCU:
http://www.rcuniverse.com/forum/m_28...hrottle/tm.htm
fritzke is offline Find More Posts by fritzke
Discussion Cox Throttle via Carburator Intake elaerico 1/2A Planes 28 Apr 11, 2009 10:15 AM
Wanted cox throttle sleeves shovelheadfreak Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 26, 2006 09:41 PM
Cox throttle SnoJetter Engines 5 Oct 23, 2002 10:30 PM
