Old Jun 16, 2014, 07:06 PM
Larry Dudeck's Avatar
Williamsville, NY, USA
Joined Sep 2000
New Product
F89 Scorpian drawings now available
http://www.rcgroups.com/forums/showthread.php?t=1529537
Autocad generated drawings for a beautifully rendered 1/12 scale F89 are now available. Designed for twin 70 mm EDF's with a 60" WS and retracts, AUW - ~90 ounces, 30-32 ounce/sq.ft. wing load.
Both of mine flew on a single 4000 mAhr pack, WM400's and HET 3W motors. I do think better motors with 5S or 6S packs would be a better approach as the AUW could be reduced.
While not a first timer project, anyone with a some building experience should be able to complete the plane.
If interested, look at the build thread above and contact Wm Brown direct for the drawing package. I do believe Manzanno does the laser burning.
Contact Wm via PM or email at Flower@southwind.com
http://www.rcgroups.com/forums/showt...1529537&page=9
Larry Dudeck is offline Find More Posts by Larry Dudeck
Old Jun 19, 2014, 01:19 PM
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Hi Larry, I switched from 4s to 5s minimum. The 4W will drop amps and increase watts. The packed can be resized to 3000-5s. Plus only a 30A ESC is needed. More weight savings. It gets even better with 6s
Fuzz
St. Martin is offline Find More Posts by St. Martin
Old Jun 20, 2014, 08:30 AM
Joined Sep 2000
Fuzz,
Nice to see you're still around RCG.
I know you are correct but I am backing away from RC a little. After the disastrous losses of the F4, my new F89, an A10 and a scratch-built canard type my enthusiasm for all things RC has waned considerably. In fact I stayed away from any flying for a year.
The only plane I now have flying is an HET F86 ARF. I finished it using bits and pieces I had in the junk box. The only things purchased were two (2) 3Sx2200 packs to power the HET 2W motor.
Whether or not I will delve into the 5S or 6S territory remains to be seen but right now for the foreseeable future I think I will just sit back and enjoy some stress free flying once a while.
Old Jun 20, 2014, 03:29 PM
Big gov never Works
St. Martin's Avatar
Joined Jul 2002
I understand completely, Larry. I have not worked on anything since January. I 'm just flying some foamies, that I care less about, than the "woodies". As long as we are enjoying ourselves, that all that matters.
Fuzz
Build Log F89 mkI Scorpian Larry Dudeck Electric Ducted Fan Jet Talk 158 Jun 16, 2014 06:23 PM
Discussion Pitts Special S-1 Scale Drawings Now Availible Rick Ludtke Scratchbuilt Indoor and Micro Models 10 Apr 24, 2013 11:08 PM
Question F89 Scorpian Larry Dudeck Electric Ducted Fan Jet Talk 119 Aug 10, 2012 08:46 PM
CNC drawings available now! hpghost The Builders Workshop 0 Sep 12, 2005 03:35 AM
