Old Mar 28, 2014, 08:50 PM
kiwi_craig's Avatar
New Zealand, Auckland
Joined Mar 2014
Where to get heat sink adhesive?
Guys what is the right type of adhesive for adding heat sinks, thermally conductive epoxy ? Brand /. Product number and where to get. Many thanks.
kiwi_craig is offline Find More Posts by kiwi_craig
Old Mar 28, 2014, 08:56 PM
Expert Heli Crasher
Joined Jan 2014
Do you want a truly permanent bond? Since you mention epoxy I am assuming so? Don't use an epoxy adhesive if you ever want to remove the heatsink.
http://www.amazon.com/Arctic-Silver-.../dp/B001IMN6Y6
http://www.newegg.com/Product/Produc...82E16835100013
You might (and I say might) be able to pry loose thermal tape, but don't count on it:
http://www.amazon.com/Akasa-ak-tt12-.../dp/B001GIM9V8
http://www.ebay.com/itm/1-pc-Genuine...item3f329e0cff
-Florida Heli-
Florida Heli is offline Find More Posts by Florida Heli
Old Mar 28, 2014, 11:29 PM
subpixel's Avatar
United Kingdom, England, Nottingham
Joined Dec 2007
this is good stuff and is removable unlike epoxy http://www.fasttech.com/products/0/1...rmal-glue-50ml
subpixel is online now Find More Posts by subpixel
Old Mar 29, 2014, 08:38 AM
Tucson, Az
Joined Feb 2007
Thanks for info guys. I am working on some different ideas for my Master c/ps.
One problem with stock motors is amount of heat producded during flights.
I made a heat coils for my Genius c/p from soft al. rods and helped big time. Prolonged flight and motor ran much cooler. Master would need special design to work and adhesive would be what is needed.
dankar04 is online now Find More Posts by dankar04
Old Mar 29, 2014, 08:13 PM
Groovin', not fishin'
United States, CA, Twain Harte
Joined Feb 2014
The particular heat sink I purchased for my main motor was easily (and carefully) bent to a smaller diameter so it just "clipped" snugly onto the motor. I haven't even needed to use heat sink compound, though I should. On the other hand, I will be converting to brushless in the near future, so it may be a moot point.
bassman12350 is offline Find More Posts by bassman12350
Old Mar 30, 2014, 03:22 AM
kiwi_craig's Avatar
Joined Mar 2014
Thanks guys will try the silicone stuff
Old Apr 18, 2014, 10:41 AM
Tucson, Az
Joined Feb 2007
i have not found any of this stuff yet but soon...I hope. Using heat sink etc does indeed help motors. I made some coils for both my Genius c/p;s. right away added extra flight time and much cooler runs on motors. This gives more band for buck !1 like to fly and get as much out of my birds.
Old Apr 18, 2014, 03:25 PM
Mod it like you stole it!
katoace's Avatar
Joined Jul 2009
Been using radioshack silicone heat sink for years. Keeps motors chill. Forgot to put it on the main-motor of one of my new helis(hisky hfp100) after noticing the m/m was hot as hades post flight.....squirted some on and now she only gets warm. Stuff works...........yea radio shack, check it out..........Kato p.s. Hear you go......... http://www.radioshack.com/product/in...uctId=15438946
katoace is offline Find More Posts by katoace
Wanted Heat Sink sargie63 Aircraft - Electric - Power Systems (FS/W) 0 Feb 24, 2014 07:32 AM
For Sale HK 40A ESC w/ heat sink snolord1 Aircraft - Electric - Power Systems (FS/W) 3 Feb 19, 2014 12:41 PM
Sold Sold Medusa 3400kv motor with heat sink Terkan Aircraft - Electric - Power Systems (FS/W) 10 Nov 27, 2013 04:48 PM
Question Heat sinks, where ?? old_dude Power Systems 3 Sep 20, 2009 11:09 AM
Heat sink and Heat sink compound genovia Electric Plane Talk 2 Jun 21, 2002 10:06 AM
