Old Mar 14, 2014, 10:41 AM
mensite's Avatar
Joined Feb 2012
Motor loudness
I have motor that came with my 55" corsair and have only flew it one time.
I just sounds so loud. Like a grinding sound. What could it be from. Almost scared to fly it again.
mensite is offline Find More Posts by mensite
Old Mar 14, 2014, 10:43 AM
Y=C+I+G
cmdl's Avatar
United States, CA, Rosemead
Joined Jan 2012
prop, bearings?
cmdl is online now Find More Posts by cmdl
Old Mar 14, 2014, 10:47 AM
mensite's Avatar
Joined Feb 2012
It does it even without the prop. You would think that being new it wouldn't be the bearings. Maybe they need oil
Old Mar 14, 2014, 11:51 AM
United States, ID, Burley
Joined Mar 2012
even a new motor can be fubared .. if it is new has not been nosed in on the motor then most likely a factory defect
fastfwd is offline Find More Posts by fastfwd
Old Mar 14, 2014, 01:35 PM
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
There is also the risk of a 'foreign body' in the motor causing the noise. I remember some people complaining about machining swarf being found in some motors.
Another risk is a loose or misplaced magnet.
eflightray is online now Find More Posts by eflightray
Old Mar 14, 2014, 03:09 PM
mensite's Avatar
Joined Feb 2012
What would be a good oil to use?
Old Mar 14, 2014, 03:33 PM
elfwreck's Avatar
United States, CA, Oakland
Joined Dec 2002
Hey now,
The best oil for most motor bearings in our BL motors is... None.
Genenerally they are sealed bearings and the few that aren't generally have instruction on what oil to use.
If its a brand new motor and its making a *grinding* sound and not a squeak or squeel then its:
1) very bad bearings. Like beyond gone. Remedy: return it NOW!
2) machining schrapnel. If you know how and want to; open it up and clean every last bit out. Check the windings ajd all around the magnets. Youll really have to work to get ferrite metal out. Or better, return it NOW!
3) mismounted or out of true bell. Attempt a reset and *maybe* try and true the bell. Again much better to RETURN IT NOW!!!
Does any of this help?
Basically if its new and not right (grinding noises are not right). Its always best
to return it. Always.
RobII
elfwreck is offline Find More Posts by elfwreck
Discussion Meanwell Power supply way to Loud!! Sovrin Batteries and Chargers 0 Nov 13, 2013 03:01 AM
Discussion new pinion is verry loud? Higgins909 On-road Cars 1 Sep 25, 2013 12:06 AM
Discussion Loud Blue Wonder - Loud motors scottflight Electric Motor Design and Construction 12 Jul 05, 2008 09:25 AM
BL motor twiching and making loud noises during flight!!!!??? kindjordan Electric Plane Talk 0 Oct 04, 2004 07:48 AM
Model Motors AC1215 EXTREME Geared Brushless Motor, Loud?? synergy Power Systems 0 Jun 05, 2004 09:18 AM
