Old Aug 26, 2013, 06:45 PM
United States, WA, Puyallup
Joined Dec 2001
Driver for FUIM2
Have been unsuccessful to use the FMA PC Interface.FUIM2
Downloaded the drivers and when I attempt to use the device I receive and error message that the device driver software was not successfully installed , the device status is:"device is not configured correctly. (Code 1) "
Using win 7 op
Is this a device problem or software?
Anyway of fixing it?
RSTEARMAN is online now Find More Posts by RSTEARMAN
Old Aug 26, 2013, 07:38 PM
Seattle
Joined Sep 2007
Here's the link to the drivers page. Select the driver for FUIM2 Vista (it also works on W7)
http://www.revolectrix.com/new_appli...re/pc.usb.html
Gregor99 is offline Find More Posts by Gregor99
Latest blog entry: Dual Powerlab Case Project
Old Aug 26, 2013, 08:26 PM
Joined Dec 2001
Thanks for the reply, that's the link I have been using.without success.
Old Aug 26, 2013, 08:53 PM
Seattle
Joined Sep 2007
If you haven't tried this already, be sure the FUIM is not connected to the USB port when you install the driver. Also double check that you are using a FUIM2 not a FUIM3.
http://revolectrix.com/faqs.htm?category=53
If that fails, I'd contact Howard at FMA in the morning.
Found Looking for a .5 mm hex driver for a 1 mm hex grub screw LcJ Aircraft - General - Miscellaneous (FS/W) 13 Jun 22, 2013 08:51 AM
Found Wanted: FMA/Revolectrix/Cellpro FUIM2 or FUIM3 PC interface adapter LittleMo Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 11, 2013 08:20 AM
Discussion FUIM2 with win 7 meanbaby FMA Direct 4 Apr 07, 2011 04:20 PM
Wanted FMA CELLPRO Interface Module for 2 way data (FUIM2 or 3) earaoz Aircraft - Electric - Batteries & Chargers (FS/W) 0 Jan 21, 2011 09:30 PM
Help! FUIM2 -- Whats in side? Zeta Phoenix DIY Electronics 0 Dec 22, 2009 03:51 AM
