Old Jul 26, 2013, 02:55 PM
Heavy thinker..I mean tinkerer
TheBlood+'s Avatar
Canada, ON, Aylmer
Joined Apr 2009
Himodel 150A and HK YEP 150A ESC's
Are these two ESC's the same? They sure look like it.
http://hobbyking.com/hobbyking/store...ontroller.html
http://www.himodel.com/electric/ICE_...0A-ICE_SB.html
Has anybody had experience with either of these? Are they ok for F5D use?
Just curious on your thoughts, I know Voo Doo used the Himodel 150 in his Pyro Swist.
TheBlood+ is offline Find More Posts by TheBlood+
Old Jul 26, 2013, 03:26 PM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
thers been discussion about these before, my 100 and 150a YEp esc do run nice, no problems at all----- cant say if the Himodel and YEP are the same..
did you read the other thread? the one comparing YEP anf YGE esc,,, some info there also..
I can say, both the 100 and my two 150 YEP does handle the amps... do they hold up for years ?? dont know, time will tell..
if voodoos himodel 150a esc did run fine on 5s and 6s? in his 230+ mph swist, Im sure it will be ok in any other plane that is less demanding,,, the question is: is the himodel and yep same?
sebbe is offline Find More Posts by sebbe
Old Jul 26, 2013, 05:47 PM
Aka: Tom Jenkins
ApexAero's Avatar
Palm Beach County, Fl.
Joined Aug 2008
Say I just ordered one this morning, the price seems to vary from 56 to 49, must be if you sign in or not.
Hi sebbe, you've had good use with the 150? Is there a english manual programming sheet any place? the closest I could find is this but don't know how to translate it.http://www.yge.de/pdf/RC-Setup.pdf
ApexAero is offline Find More Posts by ApexAero
Old Jul 27, 2013, 02:52 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
hi, you can download it from HK, go to the esc, and klick on the tab: files, there it is, BUT i is not easy to understand how to program it by stick, "%"%"%""&&"&%
you should of bought the program card..
The esc comes in helimode, so you have to change that first, I will tell you how to do it, just PM me, even if the manual states how, its not easy to understand, hehe..
From what Ive read, most seem to be happy with this 100 and 150A YEP, you will always find one ore two that are not, but that goes for castle Creation also
YES, I have tried it up to 150Amp draw, static, for a few times, both my 150A esc:s, runs nice,, dont heat up so much quick, not more then my other Plush esc 60, and 80A anyway..
I cant find any downsides to the esc yet, it runs smooth, start is ok, pretty soft, have not tried the break yet, but for my setups I dont need it anyway..as I said, I dont know how long it will hold up, but Im sure by looking at the layup/electronics/solder it looks as good or better then the Plush series, and I have Plush esc:s that have been flawless for many many years now, not one has given up out of 40-50 pieces,, that GOOD..
Also I dont know how it deals with 170 or more Amps, as I have not tried, but Im sure it will handle overload as good as any other esc for short times, but cant tell... maybee you can try to get some +200A burstes
Sebbe
Old Jul 27, 2013, 04:44 AM
savneo's Avatar
Cyprus
Joined Mar 2012
Hi sebbe what is the overal size of the 100 amp yep and the150? The web sight only had width and length
savneo is offline Find More Posts by savneo
Old Jul 27, 2013, 05:18 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Hi sebbe, Yes, the first thing would be to change the soft start heli mode. It seems the pwm is 8hz and timing is 18* set at the factory, HK didn't have the card in stock so will PM you when needed, thanks.
Since this is a high performance thread, what I am building is a 70mm speed jet. It looks like a zagi with a nacelle only way cooler. I used an old 1112-2d I re-shafted and re-bearinged, a 12 blade CS fan and 'Oh My' what power this thing needs to turn enough to produce 3000 watts and a 220mph efflux. I tested on a cc160 with the fan in modified velocity nacelle, check the graph please, do you think the esc will survive if mounted in good air?(very quiet also!)
Old Jul 27, 2013, 08:24 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
savneo , measures of the 150A is: 68mm x 32.2mm x 18.69mm(thickest part) , weight: 94 gram.
my 100A YEp is inside my Shoestring cant measure that, but I think it has smae measures but is thinner..
Old Jul 27, 2013, 08:27 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
ApexAero , I like the idea of very fast 70mm edf. nice,, pictures ??
They say the 150A YEP can take 170A in burstes, but I guees it all depends on cooling. 150A for burstes like 10-20 seconds, then half throttle a while then 10 seconds and so on,, the esc can take 150Amps, tested... gets warm but not hot,,, guess you have to test if it can take more, Im sure 170A is no problem if good cooling, but cant promise it will survive all day long at those Amps....
Old Jul 27, 2013, 09:56 AM
ROV Pilot
jijohans's Avatar
Norway
Joined May 2002
Sebbe: have you connected a 4 cell rx battery with the yep 150 bec?
jijohans is offline Find More Posts by jijohans
Old Jul 27, 2013, 10:23 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
You asked, here it is, have the cores and materials, just working out the details!
(the bmp did not appear correctly) using mother board graffix now, the g-force card just died..
Old Jul 27, 2013, 10:24 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
nope, dont dare
Old Jul 27, 2013, 10:27 AM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
ApexAero , so nice, I really like those lines, looks super fast on paper,,, so the esc will be where? outlet of fan or in free air..
What the wingspan, and I assume you will bungy start it ?
Old Jul 27, 2013, 11:13 AM
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
Span is 36.5in/ 950mm 350 sq in/2250sq cm
Esc, hope to mount it on the low pressure side of the hump in front of the fan, surface mounted like my swept forward wing, the wire tail exit to the fan will be good for battery heat exit also,
edit: forgot to ask if you're familiar with a zagi style wing, I did the CG at 15% mac. What do you think?
Old Jul 27, 2013, 02:15 PM
"The Judge"
sebbe's Avatar
Sweden
Joined Feb 2006
ok, I like the span, not so small..... Good luck man,,, ...
Old Jul 28, 2013, 10:08 AM
Joined Apr 2008
Hey Sebbe, will a himodel or YEP 150A fit in an xplane OK?
thecrawfords67 is offline Find More Posts by thecrawfords67
Discussion YEP 150A from hobbyking on Goblin 630? HeavensAce Large Electric Helis 1 Jul 17, 2013 07:45 AM
Wanted Yep/Himodel Programming card Sakuji Aircraft - Electric - Power Systems (FS/W) 1 Apr 12, 2013 11:25 AM
Sold Himodel ICE 150A ESC bluelevel Aircraft - Electric - Power Systems (FS/W) 4 Feb 09, 2013 07:31 PM
Wanted 2 100a yep ESC's garrettt04s Aircraft - Electric - Power Systems (FS/W) 0 Jan 27, 2013 06:48 AM
Help! Reversing direction on YGE/YEP/HiModel 120HV ESC murdnunoc Power Systems 5 Jan 13, 2013 02:14 PM
