This thread is privately moderated by igotit, who may elect to delete unwanted replies.
Old May 04, 2013, 10:11 AM
United States, LA, Houma
Joined Jun 2008
Trader Rating: 24
thanx fireball
6 sets left
igotit is offline Find More Posts by igotit
Old May 04, 2013, 10:32 AM
Grumpa Tom
Kmot's Avatar
Joined Sep 2003
Trader Rating: 68
Glad I was able to point you in the right direction fireballv8.
Kmot is offline Find More Posts by Kmot
Old May 05, 2013, 07:23 AM
Australia, ACT, Symonston
Joined May 2013
Trader Rating: 1
thanks a lot guys, i'm really pleased that i got a line on the gears
looking forward to getting them, shimmed and adjusted my old gears,
but their a little noisy now, think I burred a tooth, getting them back together, so
cant wait for the new ones
here's a pic of the boat on the water
fireballv8 is offline Find More Posts by fireballv8
Old May 13, 2013, 03:08 AM
Joined May 2013
Trader Rating: 1
I recived the gears to day, very pleased, going to fit one set straight away. just as soon as I can get to the work bench, got guests at the mo'
Old May 14, 2013, 04:06 AM
Joined Jun 2008
Trader Rating: 24
cant wait to hear the results,some shimming may be required.not all he ep1s lower units were machined exact.i sent you 2 sets with different thickness shoulders on them.you may not need to shim at all.
Old May 22, 2013, 12:56 AM
Joined May 2013
Trader Rating: 1
Ok, fitted and test run the gears, all good. I had to try a few different combinations of the 4 gears to get the best result, they were a bit tight, locking up at first, but I got it sorted, so all good !!!
I gave the boat a good run yesterday, went well. I'm happy with the new gears.
I did a silly thing with the motor however , Running up some rapids, that wern't QUITE deep enough,had a bit of trouble - now instead of a propeller, I have only a HUB. So now I need to find a EP1 prop. I had a set of props that i grabbed a while ago, slightly different, smaller blades, same pitch, same diameter, larger hole. I put one of those on with a brass tube as a spacer, tried it out, and the boat performs slightly BETTER ? cant work that one out
Old May 22, 2013, 05:04 PM
Joined Jun 2008
Trader Rating: 24
im glad someone finally installed and tested these gears.remember to shim accordingly and check lube and mesh every couple runs.
and thanx!
Old May 23, 2013, 06:50 AM
Lipoly Killer
Frank Hurd's Avatar
Gulfport/Biloxi Biloxi Reg, Mississippi, United States
Joined Dec 2000
Trader Rating: 56
Oops!
I sent $33. I will send the other $3.00!
Frank
Frank Hurd is online now Find More Posts by Frank Hurd
Old Aug 24, 2013, 07:24 PM
Joined Jun 2008
Trader Rating: 24
have a few sets left!
Old Sep 30, 2013, 11:44 PM
Joined Jun 2008
Trader Rating: 24
still here!
Old May 30, 2014, 08:06 PM
Joined Jun 2008
Trader Rating: 24
anyone interested $36 per set
Discussion ep1 harder gears available in small quanity. igotit Racing Boats - Electric 5 May 04, 2013 10:56 AM
Discussion ep-1 harder gears available in small quanity. igotit Scale Boats 38 Dec 06, 2012 08:59 PM
Discussion A small challenge: Can you in 1 hour or less.. stonerscolony Flying Wings 7 Jul 11, 2012 12:19 PM
Help! Small Quanity Enameled Wire Vendor 43851E Electric Motor Design and Construction 6 Jul 04, 2012 11:10 AM
Gear Pulller for GWS and other small drives is available Bleriot Parkflyers 13 Apr 12, 2002 02:33 AM
