Old May 17, 2001, 10:46 PM
Rochester, New York
Joined May 2001
Twinstar power Cutout on Buddy Box Flight
During the first training flight with my
friends new twinstar, at the point of transfer of control to the buddy box the motors would cut out. He has a Focus 4
for the master and a Futaba SkySport Buddybox. The ESC is a Pegasus 35 with
supplied 6vsp400's with no additional capacitors other than the built in ones.
The throttle setting was the same as the master. Yes the motors would resume power,
and it was intermitten at times. Several
flights were had and the problem was happening often enough to be troublesome.
8 Cell 1700 pack supplied power for very
spirited flights. The BEC is enabled.
Does anyone have any ideas?
Kodaflyer is offline Find More Posts by Kodaflyer
Old May 17, 2001, 11:55 PM
United States, CA, Anaheim
Joined Aug 1999
It's probably the communication between your Futaba and his Hitek. I'm suprised that it worked at all. Try another Hitek transmitter or Futaba. In other words, try using the same brand of transmitters and see if it works. I've never had any luck connecting different brands together. IF you can get the Futaba and Hitek to talk to each other, make sure that your throw distances (the amount of servo travel) are set alike.
Gene is offline Find More Posts by Gene
Old May 18, 2001, 09:15 AM
Rhode Island
Joined Oct 2000
Try flipping the throttle reverse switch on the Futaba. Futaba Tx's need to have the throttle reversed to work with just about any speed controller on the market whereas Hitec's don't.
BobK is offline Find More Posts by BobK
Discussion Futaba buddy box on sale. HankF Simulators 0 May 04, 2006 05:21 PM
WTB: 6 ch Tx good enough for buddy box & flight sim skid2964 Aircraft - General - Radio Equipment (FS/W) 0 Jan 04, 2005 02:29 PM
Futuba Skysport 4 Channel Buddy Box// Flight Sim shawnsp400 Fuel Plane Talk 0 Dec 11, 2003 01:42 PM
Using the great planes Real Flight controller as a buddy box? Peter Young Electric Plane Talk 4 Nov 08, 2003 09:28 PM
Real Flight with TX interface, Will Buddy box work? Crash King Electric Plane Talk 0 Dec 17, 2001 10:54 AM
