Old Jan 28, 2013, 11:54 PM
Joined Dec 2010
Blade SR 120 spinning problem
New Heli-pilot here. I have 20 battery drains of flight with my new SR 120. It has been a great learning experience so far. Lately my bird will spin intermittently. Then next flight it hovers great. Tail motor is turning on and increases and decreases speed if you hold the bird and turn it from side to side like it should. Keeping the bird on the ground with power on, I can spin it right or left. During the last two attempts at flying, it started spinning once airborne. No serious crashes with major damage. Could the tail motor be going out? Could it be wiring? I am at a lose. I have inspected the wires to the circuit board and connections and all is fine. Anyone else with an SR120 have this problem?
Thanks for your time
Yamabiker
yamabiker is offline Find More Posts by yamabiker
Old Jan 29, 2013, 01:15 AM
Fly Runaway Fans
United States, TX, Fort Worth
Joined Jan 2009
If the tailrotor has ever collided with something, the internal ridge that couples it to the motor may have been chipped.
That small connector near the motor can be intermittent.
The motor itself is not the sturdiest. Most give more than 20 flights but not all.
arbilab is offline Find More Posts by arbilab
Old Jan 29, 2013, 01:24 AM
Joined Dec 2010
Thanks. I will check that.
Yamabiker
Old Jan 29, 2013, 01:48 AM
Still a N00B
lebaez's Avatar
United States, TX, Odessa
Joined Mar 2012
I had that problem once and it was the tail motor, but I had crashed it if I remember correctly. Now I put some heat shrink over the wires to protect them a little. So check that out also, I had a bit of a spinning issue, more of a drift (not as bad as your sounds) and my fly bar was bent.
I ended up replacing tail motor, blades, flybar and swash, so I'm not sure which one fixed it, but like I said, it was from a crash, so there was a cause. I'm not sure what yours could be except the tail motor.
lebaez is offline Find More Posts by lebaez
Discussion Blade 120 SR Cannot Hold Altitude W/Phoenix gapi Simulators 6 Feb 09, 2013 05:55 PM
Discussion Blade 120 SR Drops Like A Rock In Phoenix gapi Beginner Training Area (Heli-Electric) 5 Jan 16, 2013 09:04 AM
Discussion Brand new Blade 120 SR, Massive TBE! ripzeus Micro Helis 15 Jan 14, 2013 06:16 PM
Sold Blade 120 SR BNF scottyp Aircraft - Electric - Helis (FS/W) 0 Jan 05, 2013 10:31 PM
Sold Blade 120 SR BNF shahram72 Aircraft - Electric - Helis (FS/W) 2 Jan 05, 2013 08:57 PM
