Old Nov 27, 2012, 11:52 PM
Love the sport, not the plane
Hawaii
Joined Oct 2009
More Power Needed for T-Rex 450
I am flying my trex 450 se v2 with a homebuilt 3-axis gyro stabilized cam mount, go pro, and downlink system (fpv). It's very heavy. It can hover at a good bit over half throttle, and climbs slowly. I don't have enough power to pull out of sticky situations. My flight times are down at about 4 minutes. How do I get more power, and longer flight times?
My current setup is a 60amp esc, tp 2100mah 3s, stock carbon blades, and stock align blue inrunner. I recently tried out the hk 4400kv outrunner, but it had the exact same performance as the stock align motor.
http://www.hobbyking.com/hobbyking/s...dProduct=11177
Any suggestions on different blades, batt, or motor would be greatly appreciated.
Dylan
dylantorquerol is offline Find More Posts by dylantorquerol
Old Nov 28, 2012, 04:41 PM
CP heli ≠ 3D heli
Gedexas's Avatar
United States, NJ, Point Pleasant Beach
Joined Mar 2009
Is it possible to shed some weight off the FPV/stabilisation system?
If you HAVE to fly a 450 and can't get a quad or a bigger heli, then increasing number of batteries and cell count (with appropriate ESC and motor upgrade) is the only real option, 6S maybe?
You would really benefit from longer blades too, which means you're going to be stretching the heli.
Most obviously, your camera and FPV equipment is too heavy for a 450, so you'll most likely end up cutting through the BS and getting a larger heli or stretching the one you have, by which process you will end up with a larger heli anyway.
Gedexas is offline Find More Posts by Gedexas
Old Nov 29, 2012, 12:42 AM
Australia, VIC
Joined Dec 2011
Hmmmm
Depending on where the weight is ?
2650 3S battery [ greater capacity ] also more weight !
Bigger better motor and ESC / more power = less run time ..
Longer rotor blades - you can run 335 no problems HK sells them ..
Motor ? What pinion ? I would try dropping the pinion to 10T or 11T since the KV is 4400 , let the motor spin , but slow down the head , increase torque effect with lower tooth pinion , and slap on some larger blades .. I have run up to 350mm blades without stretching [ could be risky ] but just gentle hovering and flying ..
Rotor Blades - Try these ?
old4570 is offline Find More Posts by old4570
Old Dec 01, 2012, 04:58 PM
My dog is PERFECT in my eyes
Joined Mar 2010
I agree with an 11T pinion, and find a way to mount a 3S1P 3000mah/30c battery under the frame that agrees with CG. Scalers are heavy, so I run the above with acceptable results.
metalbenderusn is offline Find More Posts by metalbenderusn
For Sale 2 T-REX 450 with LOTS of parts. Needs to go! OrlandoP Aircraft - Electric - Helis (FS/W) 1 Aug 17, 2012 01:08 PM
Discussion Need help! T-Rex 450 Sport Dorantana Beginner Training Area (Heli-Electric) 8 Aug 05, 2012 11:36 PM
For Sale FS: T-Rex 250SE AR6110E BNF + 4 Hyperions, Carrying Case, Spares, and More for $450! jmpwnd Aircraft - Electric - Helis (FS/W) 8 Feb 09, 2010 08:33 PM
For Sale Align T-REX 450 V2 and Align T-rex SA 450 For Sale fabiano_2002 Aircraft - Electric - Helis (FS/W) 2 Jan 12, 2009 10:37 PM
