Old Nov 26, 2012, 09:37 PM
Canada, ON, Newmarket
Joined Dec 2005
55mm A4 inlet design
I've been hot wire cutting small pusher jets and have built a 50mm edf. I'm now working on a 55mm A4 and need some input on the intake design. Which of the two ideas shown is better? Having the two intake ducts merge ahead of the fan or merge at the face of the fan.
gdimonte is offline Find More Posts by gdimonte
Old Nov 26, 2012, 09:43 PM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Both will work equally well, but the top one will not 'whine' as much as the bottom one.
DanSavage is offline Find More Posts by DanSavage
Old Nov 28, 2012, 08:24 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
i've found that some space between the merge and fan is best unless you do constant area ducts where the fan only get air not the spinner ,with those you need at least a inch between the merge and fan blades...most of the time ...some fan require a bit more.
AIR SALLY is offline Find More Posts by AIR SALLY
Old Nov 30, 2012, 07:25 AM
Joined Dec 2005
Thanks for the input. Here's another question. I'm using GWS fans that have a lip on them. My inlet duct diameter is the same as the fan inner diameter. This leaves me with a small gap where the fan face meets the inlet. What's the best way to deal with this?
Old Nov 30, 2012, 11:11 AM
It wasn't me...
DanSavage's Avatar
Trabuco Canyon, CA
Joined Nov 2000
Without an actual measurement to quantify what 'small' means, I'd say leave it alone as it won't affect performance.
Old Nov 30, 2012, 12:44 PM
Joined Dec 2005
I don't have the fan with me right now but, here's roughly what I'm dealing with.
Old Dec 03, 2012, 11:27 PM
deltas are cool
AIR SALLY's Avatar
Tehachapi ,CA.
Joined Apr 2006
that wont hurt anything ...if any thing it will help stop reversion
Old Dec 04, 2012, 10:48 AM
Joined Dec 2005
Good to know. That simplifies the build.
Sorry to drag this out but, I have another question regarding your note above on constant area inlets. Would that design provide much improvement over the basic inlet shown above? Is it worth the extra effort?
Found Alfa A4 Inlet Tube DavidN Aircraft - Electric - Jets (FS/W) 5 Nov 17, 2011 03:13 PM
Discussion Inlet design questions- HELP PLEASE funkworks Electric Ducted Fan Jet Talk 5 Apr 10, 2009 03:32 PM
Discussion Inlet duct designs? ShadesOfGray Electric Ducted Fan Jet Talk 11 Nov 30, 2008 08:49 PM
Inlet ducting/thrust tube design TGoodwin Electric Ducted Fan Jet Talk 135 Jun 17, 2007 01:25 AM
Inlet duct design? (EDF-50, EDF-75) meteor Electric Ducted Fan Jet Talk 8 Mar 21, 2003 08:53 AM
