Old Sep 21, 2012, 01:58 PM
United States, OH, Troy
Help!
Centering DX6i Gear Channel?
Don't really know where else to put this question : Is there a way to center the gear channel and deactivate the gear switch on a DX6i?
Spamman127 is offline Find More Posts by Spamman127
Old Sep 22, 2012, 04:55 AM
RCvertt's Avatar
Joined Aug 2007
I don't have that radio but I would try using the travel adjustment on the gear channel. Set the travel to zero in both directions then it won't matter which position the switch is in.
Then use subtrim on the gear channel to fine tune where you want the neutral position to be.
RCvertt is offline Find More Posts by RCvertt
Old Sep 22, 2012, 02:57 PM
Nope that didn't work. Any other ideas?
Old Sep 22, 2012, 06:08 PM
RC Adddict
Wilfor's Avatar
Canada, BC, Williams Lake
Joined Jan 2010
i would ask this in the radio section . If it can be done someone there will know
http://www.rcgroups.com/radios-135/
Wilfor is offline Find More Posts by Wilfor
Old Sep 22, 2012, 11:04 PM
rajazo's Avatar
Chile
Joined Jul 2010
use this little program mix (patent pending)::
MAS (master)=GEAR, SLV (slave)=GEAR, MIX=-100%, -100%, SWT (switch)=ON (always on)
(check pages 70 to 73 in your manual)
how it works?
switch down tells move -100%, but the program tells move the same but in the other way at the same time, then remains at 0 position (center).... the same with switch up...
that's all
rajazo is online now Find More Posts by rajazo
Latest blog entry: OV10 bronco
Old Oct 10, 2012, 10:48 PM
Awesome, that is exactly what i was looking for! Thanks
Help! DX8 Airware 2.05 channel centers and end points not the same as 2.04? Elios000 Radios 2 Oct 22, 2012 08:38 AM
Sold Spektrum DX6I DSMX six channel with four 6 channel receivers NZ7C Aircraft - General - Radio Equipment (FS/W) 1 Sep 18, 2012 07:57 PM
Help! How to center JR DS285 servo last gear gmg2001br Electric Heli Talk 3 Jun 17, 2012 10:18 PM
Question DX6i programming flap and gear channel chachaya Radios 5 Dec 09, 2010 09:47 PM
Help! Can I turn my Navigation lights on and off with my DX6i and gear channel on RX dolbydarma Night Flying 6 Nov 17, 2010 07:49 PM
