Old Sep 18, 2012, 09:44 PM
I ain't afraid of no gravity
United States, IL, Bolingbrook
Joined Jul 2012
Help!
Rustler Spur
I have a rustler running the sidewinder 5700kv and love it. I'm getting about 60 out of it but my spur gear keeps striping. I've went through 3 in the past 5 days. I know its not the gear mesh because the guy at my LHS did it for me. He told me how to set the slipper clutch. I listened and it striped while i was testing. Is this new system too much power for the gears.
malik98 is online now Find More Posts by malik98
Old Sep 18, 2012, 10:33 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Just because the guy at the LHS did it doesn't mean the mesh is right... how much slop is there before the gear was ruined? There should be a tiny bit of play, but not a lot at all.
wparsons is offline Find More Posts by wparsons
Old Sep 18, 2012, 10:50 PM
Joined Jul 2012
What do you mean by slop. There is a tiny bit of give
Old Sep 19, 2012, 11:10 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
How much space/play/slop is there. If it's too tight or too loose you can damage the gear. You shouldn't be ruining the gear if the mesh is right with a 5700kv motor.
How are you driving it, are you blasting around at full throttle, then slamming on breaks/reverse, then flooring it again, etc?
Old Sep 19, 2012, 09:41 PM
Joined Jul 2012
There is a tiny gap I use the paper method. Most of the time it's at full speed with little stopping
Old Sep 19, 2012, 10:17 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Are you using a high quality pinion gear? How are the bearings on the main (top) shaft of the gearbox?
There's very little load on the gears at full speed compared to lots of acceleration and stopping, so if anything you're putting less load on the gears than most people do.
Old Sep 19, 2012, 11:13 PM
Joined Jul 2012
The pinion gear is traxxas brand. I'm not sure about the bearings. Are they the ones on the spur gear
Old Sep 20, 2012, 10:29 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
They're inside the gearbox, you can check that by seeing if there is an wiggle in any direction with the spur gear. If you can move it in any direction you have your source of the issue right there.
Old Sep 20, 2012, 09:41 PM
Joined Jul 2012
I opened the box and all the bearings look good. What else should I check
Old Sep 20, 2012, 11:01 PM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Did you try wiggling the gear before tearing the gearbox apart? It doesn't matter what the bearings look like, check for a gear that can move.
Also check to make sure the spur gear is fully centered (check the mesh through a full rotation of the spur gear).
Old Sep 20, 2012, 11:23 PM
Joined Jul 2012
It barely moved and can do a full rotation
Old Sep 21, 2012, 07:40 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
Barely moved is possibly too much movement... the spur on my 22T (or older XXT as well) can't budget at all except to rotate.
Are there any points where it can move and tighten up the mesh or make it too loose?
Old Sep 21, 2012, 08:06 AM
Joined Jul 2012
I tightened it and it doesn't move at all now
Old Sep 21, 2012, 09:41 AM
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
What did you tighten...?
Old Sep 21, 2012, 04:05 PM
Joined Jul 2012
The slipper clutch nut
For Sale HPI Savage Flux motor mount and spur heavy duty spur gear metalhead1986 Cars - Cars and Parts (FS/W) 0 Jul 13, 2012 11:16 PM
Wanted Wanted: Spur Gear for Turnigy 1/16 monster beetle FIREWALL Cars - Trucks and Parts (FS/W) 3 Apr 27, 2012 09:41 AM
Sold Traxxas Stampede 4x4 Wheel Nuts And Clear Spur Gear Cover. Curt S Cars - Trucks and Parts (FS/W) 0 Apr 02, 2012 02:17 PM
Question Spur gears & Clutch Bells RcBoatin812 Nitro and Glow Power Cars 3 Mar 25, 2012 07:51 PM
Discussion rustler spur gear problem, help please! jayt0e Off-road Cars 7 Jun 08, 2008 03:50 AM
