Old Apr 19, 2012, 05:08 PM
CJRAY's Avatar
United States, GA, LaGrange
Joined Mar 2012
Cool
Great Planes Patriot converted to electric
After doing much research, I pulled my crashed Patriot out of the attic and went to work rebuilding it to convert it to electric. I had taken a hit on the old 72mhz back in '03-'04 and it nosed in on landing right over the paved runway tearing about 8 inches of the right side fuse off. Luckily, did I not only pick up all the pieces, I actually kept and found them in the attic, which made the rebuild drastically easier. Anyway, after rebuilding, I had to pick my poison. After doing much research online, I wasn't finding much on Patriot conversions so I went at it on my own. Since this was an experiment, I tried to keep it reasonably priced knowing that I could spend some dough on a very good motor later. Using Motocal, I ended up going with the Great Planes Ammo inrunner 36-88-1280, swinging an APC 9x6 prop, Castle 100A ESC, and will be running on two parallel 6S 3000mah batteries. I also pulled the mangled Hobbico mechanical retracts(remember, I was landing when it went in) and replaced them with a set of RC Lander electric retracts and a set of suspension struts. Due to the Ammo motor, and coming from nitro, I enclosed the right side of the cowl, had to lengthen it buy about 3/4", and made an intake on the bottom side for cooling air. I also had to make a custom motor mount for it, one that would be narrow enough for the cowl, but long enough also. I have everything installed and am just waiting on my spinner to come off back order to test this thing out. It came out to 5lbs RTF, minus the batteries, which I thought was pretty good, and according to MotoCal, this setup should push it to 110mph at full throttle.We will see on that when I get to test fly it. Should be fun.
This was it in '03-'04 on an O.S. nitro with a tuned pipe. Yes, it was complete with missle rails and missles.......
and this is it now on clean electric power........
CJRAY is offline Find More Posts by CJRAY
Old Apr 19, 2012, 05:51 PM
jmd87's Avatar
United States, MS, Starkville
Joined May 2009
That's gonna scream! Keep us updated
jmd87 is offline Find More Posts by jmd87
Old Apr 19, 2012, 06:08 PM
CJRAY's Avatar
Joined Mar 2012
I hope so! Will do.
Old Apr 20, 2012, 03:06 PM
CJRAY's Avatar
Joined Mar 2012
started another thread for this post....
Old Apr 20, 2012, 04:55 PM
Toysrme's Avatar
Birmingham, Alabama
Joined Jun 2002
just make sure if you ditched the old 72mhz system for a new 2.4ghz system, that the new system is up to it. beware on these quick planes that cover a lot of ground in a hurry. 2.4ghz range is... half or less than decent 72mhz ever had.
just be very sure to do a good range check on it.
looks baller. love the blue.
Toysrme is offline Find More Posts by Toysrme
Old Apr 20, 2012, 05:55 PM
CJRAY's Avatar
Joined Mar 2012
Yeah, I'm flying Spectrum now. Gave the old 9C a rest. It would scream before, just wondering how it's going to do now. Thanks!
Old Apr 26, 2012, 09:35 PM
CJRAY's Avatar
Joined Mar 2012
Well, I still need a watt meter, but I ran it up to about half throttle, and it has some power.....WOW!
Old May 01, 2012, 04:43 PM
CJRAY's Avatar
Joined Mar 2012
Just FYI, on 6s power, I was getting 14500 rpm at 50% throttle! I remade a 6s pack with a bad cell into a 5s for this thing, that will slow it down but still has very, very good power. I borrowed a watt meter from a fellow club member, but noticed that it's only rated for 100A and I should be pulling more than that, at least with the 6s, and I don't want to cook someone else's meter. It's a Watt's Up. Any suggestions?
Old May 10, 2012, 08:45 AM
CJRAY's Avatar
Joined Mar 2012
figured it out.
Old May 10, 2012, 06:14 PM
CJRAY's Avatar
Joined Mar 2012
Old May 11, 2012, 07:28 AM
RC pilot by soul
Israel
Joined Apr 2005
perhaps its LVC with the 5S ?
i3dm is offline Find More Posts by i3dm
Old May 11, 2012, 11:33 AM
CJRAY's Avatar
Joined Mar 2012
Maybe, but it should be pushing plenty with a 5s, doesn't mean it is though. I don;t have a watt meter that will cover the amps I'm pulling to check it so.....
Old May 11, 2012, 11:54 AM
RC pilot by soul
Israel
Joined Apr 2005
LVC is not related to amps.
Old May 11, 2012, 12:07 PM
CJRAY's Avatar
Joined Mar 2012
Yeah, shouldn't have said that, I wasn't thinking. It's been a bad week. Don't think 18.5v is enough? The motor is supposed to run on 5s or 6s. It's not a big deal, I'm going to run 6s, but thought I might be able to run both.
For Sale Great Planes Patriot Kit NIB imodel Aircraft - Fuel - Airplanes (FS/W) 1 May 20, 2012 01:37 PM
Wanted Great Planes Patriot XL kit Jim Oliver Aircraft - Fuel - Airplanes (FS/W) 6 Feb 07, 2012 09:31 AM
Sold Great planes patriot RTF pickup only $150.00 snomobila Aircraft - Fuel - Airplanes (FS/W) 0 Feb 01, 2012 02:50 PM
For Sale Great Planes Patriot - 40, TWO airplanes HeloDrvr Aircraft - Fuel - Airplanes (FS/W) 0 Sep 28, 2011 10:50 PM
Great Planes Patriot convert, possible?? Muah Electric Ducted Fan Jet Talk 5 Aug 13, 2003 08:41 PM
