Old Feb 03, 2012, 04:43 AM
Who's got the Tx ?
Boeing744's Avatar
United Kingdom, Whitchurch
Joined Jul 2010
Ecalc prop/machine/motor calculator
Does anybody use ecalc ( www.ecalc.ch ) to decide prop/motor combinations ? If so how accurate do you find it ?
Boeing744 is offline Find More Posts by Boeing744
Old Feb 03, 2012, 04:49 AM
Pants first, then shoes
Joined Jan 2011
I have found it to be very accurate sometimes and other times pretty badly off. For example the specs it uses for some rctimer motors are very wrong so you can get some inaccurate calculations for those. When the specs are correct it's very good.
Stacky is offline Find More Posts by Stacky
Old Feb 03, 2012, 12:31 PM
um, yea, I can make that crash
Wayno Complaino's Avatar
United Kingdom, England, Milton Keynes
Joined Aug 2011
I've found it quite good so far but not all products are listed and it can't take coax system into account.
The trick is to use it as a rough guide, not gosbal truth.
Wayno Complaino is online now Find More Posts by Wayno Complaino
Old Feb 06, 2012, 10:28 AM
Air Traffic Controller
United States, TN, Knoxville
Joined Aug 2011
Use it all the time. I'm not good enough to determine the accuracy over many setups, but on my quad, it was within 20 seconds on the hover time. I did take good care and entered weight, elevation MSL, temperature etc. All my components were in the drop downs as well. The MSL and temperature are important for accuracy as it calculates the density altitude for your flying area and thus, the efficiency of your motors and props as they spin. Higher temperature and altitude requires more RPM in the motors for the same thrust as the air moving over the blades is thinner.
Webheadfred is offline Find More Posts by Webheadfred
Data Motor & Prop Combo Calculator 14MHz Electric Sailplanes 2 Aug 28, 2011 07:40 AM
Help! I have becom a motor / prop calculator addict. cyclops2 Power Systems 2 Dec 14, 2010 02:00 PM
Link Prop Motor Esc calculator leadfeather Foamies (Scratchbuilt) 2 Nov 15, 2007 02:42 PM
Discussion Any prop motor watt calculator outthere? Sky-walker Power Systems 3 Jul 07, 2007 09:51 PM
electric calculator motor battery prop? 60ndown Electric Plane Talk 3 Oct 10, 2004 04:32 PM
