Old Feb 13, 2011, 07:46 PM
it's for sale
Glasgow, KY
Joined Sep 2010
Carbon z yak 54 problems
Just put together my Carbon z yak and added the electronics . I am having problems with it taking throttle. I move the left stick forward and nothing. All other control surfaces work but the ESC will just beep 3 times and nothing.
Futaba radio 6ex and with 6 channel receiver
tried reversing servo direction
trim set to zero
Any suggestions would be great~!
Full Spool is offline Find More Posts by Full Spool
Old Feb 13, 2011, 08:17 PM
Las Vegas
Joined May 2008
Reverse Channel 3 on your radio, see if that helps.
unlvace is offline Find More Posts by unlvace
Old Feb 13, 2011, 08:36 PM
it's for sale
Glasgow, KY
Joined Sep 2010
Already tried that. No luck.
Old Feb 13, 2011, 09:06 PM
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
reduce the throttle trim lever and see if the ESC will arm...
ATIS is offline Find More Posts by ATIS
Latest blog entry: maxford Nieuport 1/5th Scale
Old Feb 14, 2011, 01:09 PM
WARNING: May contain spam
Xpress..'s Avatar
United States, CA, Alpine
Joined Oct 2007
Because it's a Futaba, the throttle needs to be reversed, then try moving your throttle trim to the lowest position.
REMOVE THE PROP!!!!!
Xpress.. is offline Find More Posts by Xpress..
Old Feb 14, 2011, 06:02 PM
it's for sale
Glasgow, KY
Joined Sep 2010
Servo direction was correct and trim settings where set to zero already as stated in the original post.
Turned out to be the EPA settings on the radio, I got it fixed finally.
Discussion NEW!!!! E-Flite Carbon-Z Yak 54 BNF/PNP!!! DFflyer 3D Foamies 3907 Yesterday 12:04 PM
Cool New E-flite Carbon-Z Yak 54 miksta115 Electric Plane Talk 39 Oct 11, 2011 11:05 AM
New Product E-Flite Carbon-Z Yak 54 (48'' Wingspan 940 Watts!) Get Real 3D Foamies 1066 Feb 22, 2011 11:21 PM
Discussion Eflite carbon-z yak 54 bnf tele1974 Foamies (Kits) 12 Nov 13, 2010 06:33 AM
Discussion E-flight Carbon-Z Yak 54...Found my next plane! redhotpearl Electric Plane Talk 0 Oct 20, 2010 10:33 AM
