Old Jan 18, 2003, 01:21 PM
Ryan Nau is offline
Find More Posts by Ryan Nau
Tork it or Dork it
Ryan Nau's Avatar
Elizabethville,PA USA
Joined Jul 2000
8x720nimh with mini laser3d motor?
I have an extra geared motor from my mini laser 3d kit. I think they are a 370 motor. Can I use 8x720nimh with it? I dont know how many amps the motor draws.
Ryan Nau is offline Find More Posts by Ryan Nau
Old Jan 18, 2003, 10:38 PM
Steve McBride is offline
Find More Posts by Steve McBride
Steve McBride's Avatar
Agra, Oklahoma
Joined Feb 2000
You'll get a lot of different opinions on this, but if I recall correctly, the ML3D motor/Prop (as supplied with the kit) will draw in excess of 10A on 8 cells. Very much above where the AAA NiMH will be happy (you will see lots of voltage suppressions). If I am wrong about the current draw, then I apologize. If it is more like 5-6A then you should be fine. I almost hate to give an answer to your question because someone will argue that the AAA cells are good to 25A and fly a 12lb model with authority, etc.
Give them a shot and see how (if) hot they become.
Good luck!
Steve
Steve McBride is offline Find More Posts by Steve McBride
Sold Mini stick with CD rom motor Steve H. Aircraft - Electric - Airplanes (FS/W) 5 Jul 22, 2004 12:01 PM
F-18 with mini 480...what motor??? noahb Electric Ducted Fan Jet Talk 1 Feb 27, 2004 07:48 PM
F/S mini flying wings with epp LE,motor,props,heat sink only $37 sylair Aircraft - Electric - Airplanes (FS/W) 58 Jan 22, 2004 06:39 PM
Any opinion on Tiger Moth with Mini Max motor & 700 mah 2S Lipo ktoey Parkflyers 0 Nov 30, 2003 01:50 AM
What motor with the Mini 480 zbrubaker Electric Ducted Fan Jet Talk 9 Mar 21, 2002 06:34 PM
