Old May 31, 2007, 03:32 PM
Southern T Rex is offline
Find More Posts by Southern T Rex
Baton Rouge, Louisiana
Joined Apr 2007
trex troubles NEW to HELIS
I am new to helis. Just got a TREX 600 and am having trouble with tail going nuts . unsure of radio settings, and how to program the esc HELP from anyone with setting up a trex !!!!!!!!!!!!!!!
southern trex
baton rouge la
Southern T Rex is offline Find More Posts by Southern T Rex
Old May 31, 2007, 04:28 PM
Wheelhaus is offline
Find More Posts by Wheelhaus
volts x amps = watts.
Wheelhaus's Avatar
Denver
Joined Sep 2006
read the EHBG stickied at the top of the forum. It should have most of the information you need to set up the heli correctly. If you're new to helis, there's a lot of basics you should know before flinging that big monster into the air!
Wheelhaus is offline Find More Posts by Wheelhaus
Old Jun 01, 2007, 10:53 AM
Joined Apr 2007
what is the ehgb on the top of the forum
Old Jun 01, 2007, 11:15 AM
Xipper is online now
Find More Posts by Xipper
PNW, USA
Joined Feb 2007
Click back to the main page for the Electric Heli forum:
http://www.rcgroups.com/electric-heli-talk-17/
You will then see a sticky link at the *top* of the forum for
"EHBG/Electric Helicopter Beginner's Guide v17 *** UPDATE 10/17/2006 *** "
http://www.rcgroups.com/forums/showthread.php?t=584463
Xipper is online now Find More Posts by Xipper
Old Jun 01, 2007, 11:27 AM
zen@lanset.com is offline
Find More Posts by zen@lanset.com
unlicensed helicopter nut
zen@lanset.com's Avatar
Berkeley, California
Joined Jan 2007
Hey, Southern— is the 600 your first heli?
zen@lanset.com is offline Find More Posts by zen@lanset.com
Old Jun 01, 2007, 01:28 PM
Joined Apr 2007
not 1st heli
No, the 600 is not my first. Might as well be though. I have a blade cp
its a baby compared to rex600. I really believe the 600 is easier to hover
bacause it seems much more stable. Thanks for asking. There are not hardly any helicopter guys in baton rouge la. i have so many questions about set up ,i don,t know where to begin
thanks
southern t rex
Don Olano
Old Jun 01, 2007, 01:39 PM
TMorita is offline
Find More Posts by TMorita
San Carlos, California, United States
Joined May 2002
Yeah, if you previously had a blade CP, then you're basically only a half-step above a complete newbie since you've never had to do transmitter setup and other things.
The EHBG section on "Helicopter and Transmitter Setup" should help.
Toshi
TMorita is offline Find More Posts by TMorita
Old Jun 01, 2007, 03:18 PM
Joined Apr 2007
motor pulsing
the problem i am having now is that the stock motor seems to be pulsing
(does not hold a steady rpm) the tail reacts to this uneven rpm it is uncontrollable. what could this be . transmitter , something mechanical ,
southern trex
Old Jun 01, 2007, 03:30 PM
Joined Jan 2007
'Pulsing' sounds like an ESC in governor mode when battery voltage becomes low. That's how it tells you that it's time to land it and re-charge.
An invaluable source of specific advice on setting up your 600 can be found on HeliFreak.com. Go to Finless Bob's HeliFreak Tech Room. You must register to log on to HeliFreak but it is free. Finless Bob has made a series of videos describing how to build and set up the Trex 600 (and other heli's), and he provides these videos as free downloads.
When I set up and tweak my Trex 450 Finless is there to help, and thanks to his abundant good will I have always flown, fixed, and flown again successfully, if not especially skillfully....
Old Jun 04, 2007, 10:11 AM
Joined Apr 2007
Thanks for the info. Never registered at helifreak.com
Don Olano
southern t rex
Battery Charger Troubles - New to Electric bugleboy Parkflyers 4 Jan 14, 2003 06:33 PM
Battery Charger Troubles - New to Electric bugleboy Batteries and Chargers 2 Jan 14, 2003 04:24 PM
new helis ? that I havent heard of yet ! Choppa Nutta Electric Heli Talk 0 Jan 26, 2002 11:55 AM
New to helis and HouseFly Basketcase Electric Heli Talk 6 Dec 28, 2001 09:03 PM
