Old Dec 15, 2006, 04:53 AM
Chophop is online now
Find More Posts by Chophop
I likes Electric Flies !
Chophop's Avatar
Pleasant Valley Modelport
Joined Sep 2006
2 Cell Micro Mystery
I see more and more people using 2 cell lipos on their micros and even Esky is selling Honeybee FP's with a 2 cell lipo now. I tried one and could not get much power from the stock main or tail motor. And I read lots of complaints that others have the same problem. I could get PLENTY of power by changing the main motor to an EM350 which is a differently wound RK-370SD-4045 (stock BCP, DF4 etc.). But the DF4 does not have much proportional adjustment and I could not get the tail to spin fast enough. Also, changing to the EM350 brings a need to heatsink the stock Esky/Eflite esc. Not required, but a good idea. I read some people advance the main motor timing for 2 cell.
With my stock motors on 2 cells, I get about 3 minutes of mushy hover, don't even attempt fwd flight. With the EM350, I got 10 minutes of solid hover, and 3 more sort of mushy ones, a good land now indicator. But the tail was too mushy. Maybe 1 more tooth on the tail pinion, but that is a pain.
How are they doing it ?
CH
Chophop is online now Find More Posts by Chophop
Old Dec 15, 2006, 05:37 AM
Gino CP is offline
Find More Posts by Gino CP
Team Mulikow
Gino CP's Avatar
Manila, Philippines
Joined Oct 2006
People go with 2S lipo simply because they can't use 3S on some systems. One reason is higher voltage is restricted such as in the case of the DF4. Another reason is weight.
I use a 7.4v lipo on my Blade because I have no 8T motor to use with an 11.1v lipo. My 8cell nimh is shot so its the best I have for that heli.
Gino CP is offline Find More Posts by Gino CP
Old Dec 15, 2006, 12:23 PM
macr0t0r is offline
Find More Posts by macr0t0r
Got more toys than my kid
macr0t0r's Avatar
USA, CA, Fremont
Joined Sep 2004
Gino pretty much nails it. Some people "settle" for a 2S battery because it's more flight-time than a NiMh but without requiring modifications. For instance, a 3S pack will also work the tail-motors harder and cause them to burn out faster, unless you do the diode-mod or twin-motor mod.
A 3S pack with the proper pinion is definitely more efficient and a better performer. There's a reason whey the competitor helis use 5 and even 6-cell batteries! But, you have to set up your heli properly for it.
- Jim
macr0t0r is offline Find More Posts by macr0t0r
Old Dec 15, 2006, 02:33 PM
swatson144 is offline
Find More Posts by swatson144
That'll hold until ...
swatson144's Avatar
Hampton Roads Va.
- Jim
That may be your case but I can set my little FPs up to run on anything I want (I have a pretty extensive selection of packs most in pairs) . I use 2S by choice. 1/3 the pack weight makes a nicer heli for me. Proper motor selection and gearing is the key no matter what voltage you elect to run. For the FP 2s is ideal in my opinion because even the H DD motor don't last for long on a 3s so the answer is to add more weight in the back. The normal reason to select a higher voltage is to keep the current down and be able to run a pack that puts the heli in the "sweet spot" AUW, good power, and duration. My favorite micro gets 10 mins on about 1000mAH with hard flight. So I draw 6A average has plenty of power on a RZv2 4200kv with a 12mm feigao on the tail 2x phoenix 10A . Every thing lands pretty much room temp. I could repinion and set up for 3S, and have tried but I like 2S better. I have a HV45 ESC so I could set it up to run 12s if I thought there'd be a reason
Chophop
Too low a gear ratio won't give you enough lift on an FP. up the pinion by a tooth and try again. Pinion changing is a big part of heli life so you might as well get used to it. I have a spread of pinions for all of my helis. It allows me to run different voltages and KV motors to find the "sweet spot" where I like it best. Pinions are probably one of the cheapest modes you can make to a heli. Remember to check for heat often when testing.
Steve
swatson144 is offline Find More Posts by swatson144
Old Dec 16, 2006, 02:40 AM
Orion1024 is offline
Find More Posts by Orion1024
Orion1024's Avatar
Joined Jun 2006
You just need a stronger tail motor setup to go with that EM350. I have a dual N30 tail motor setup with 10-tooth pinions on them and it works fantastic on 2-cells. Using a 3-cell pack is the easy way to get lots of power from the main motor and good tail authority, but it will burn your motors out MUCH quicker than a 2-cell pack. Even the main motor doesn't last too long on 3-cells. The stock DF4 4-in-1 can safely run a 3-cell pack if you double-up the main motor FETs and put a small heat sink on them and the 'LD1117' voltage regulator IC.
Orion1024 is offline Find More Posts by Orion1024
Sold Cox Micro Corsair, Pixie 7, and 2 cell Lipo The Don Aircraft - Electric - Airplanes (FS/W) 4 Mar 10, 2006 05:35 PM
Sold E-Tec 2 cell 700 mAh HP Lithium Polymer LiPo Battery perfect for Cox Micro Warbird shschon Aircraft - Electric - Batteries & Chargers (FS/W) 2 Jan 13, 2006 12:23 AM
3.2 oz micro ME109 frankenfoamy Scratchbuilt Indoor and Micro Models 9 Oct 15, 2005 08:49 PM
Can I use a 2 cell brushless ESC with a single cell micro joule system? Matthew Cotten Scratchbuilt Indoor and Micro Models 2 Jul 05, 2005 09:19 AM
2 cell Hellcat epilot Scratchbuilt Indoor and Micro Models 8 Jan 05, 2002 03:44 PM
