Old Aug 26, 2006, 10:19 AM
burro breath is offline
Find More Posts by burro breath
the scene of the crash
Joined Mar 2005
Question
help with tail wag in my trex
my trex has tail wag that is consistantley left to right about 1 foot i have not changed the gyro or tx settings. i bought it used and it flew like a champ after a few crashes 6 to be precise the tail wags i have no vibrations what so ever in the head assembly and i am using a gy240 for the gyro please help me.
Burro breath
burro breath is offline Find More Posts by burro breath
Old Aug 26, 2006, 07:07 PM
bula is offline
Find More Posts by bula
Joined Jul 2006
wags
Maybe thru one of the rebuilds the rudder linkage was connected to the servo further from it. This would cause more reaction from the gyro than it did before. Try to move the linkage where it is connected to the server closer to it. I think the expresion is shorten the horn. You may want to check travel on the linkage too. Any adjustments to the tail make sure the linkage isn't binding back there. It would be eisier to try to drop the % on the gyro and see if that helps before getting into mechanical stuff.
bula is offline Find More Posts by bula
Old Aug 26, 2006, 07:59 PM
I.C.O.N. is offline
Find More Posts by I.C.O.N.
I.C.O.N.'s Avatar
Twin Cities, MN
Joined Feb 2006
Make sure all the tail grips are tight!
Tail rotors are tracking.
Boom is straight and rotors spin nice and perpindicular to the main rotors.
Tail shaft is straight.
Tail shaft is not sloppy in the bearing.
Tail slider may have excessive slop in it.
Just a few thoughts.
Good Luck,
Andy
I.C.O.N. is offline Find More Posts by I.C.O.N.
Old Aug 26, 2006, 08:25 PM
Joined Mar 2005
well i think that there is some slop in the tail gear there is a new boom and back tail grips
Discussion Gingling Noise in my Trex 450SA Tail Dan_eflyer Mini Helis 10 Apr 14, 2007 11:44 AM
Discussion Help with tail wag? cubaneight Mini Helis 12 Oct 30, 2006 08:58 AM
Help! Need a little help with tail wag.... Wren1702 Mini Helis 8 May 14, 2006 11:08 PM
Need help with the tail pulley/gear on Trex Swilson50 Mini Helis 0 Oct 09, 2005 09:15 PM
Little help with the WAA WAA in my raptor lilhoss Fuel Heli Talk 2 Jan 03, 2005 06:04 PM
