Old May 17, 2006, 08:24 PM
droydx is offline
Find More Posts by droydx
Fun ain't cheap!
droydx's Avatar
United States, CA, Santa Barbara
Joined Apr 2003
Mixing on Optic 6 for flaps on crow
The question is can you set up crow and link the ailerons with the
flaps also? My friend Glenn called Hitec and the guy he was referred to didn't really sound like he was sure when he said he didn't think so.
Has anybody figured out some trick use of the mixers to enable this? The Optic 6 is a back up transmitter for me to my Stylus. I mostly use it on simple 2 channel ships and wings. Just wondering if I can use this transmitter for some of my "full house" gliders.
Andy
droydx is offline Find More Posts by droydx
Old May 17, 2006, 08:47 PM
aaronredbaron is offline
Find More Posts by aaronredbaron
Spektrum Dev Team
aaronredbaron's Avatar
United States, IL, Champaign
Joined Apr 2002
not gonna happen...sorry get yourself a futaba 9c, a JR 9303, an airtronics stylus, a multiplex evo, or something of that class or higher, you will be happy with your investment...you get what you pay for
aaronredbaron is offline Find More Posts by aaronredbaron
Old May 17, 2006, 09:54 PM
slopemeno is offline
Find More Posts by slopemeno
more casual than stylish....
slopemeno's Avatar
Joined Jan 2003
Sharkbait and I tried six ways from Sunday to make this work on his Miniblade, and heres what happened: If you use a reversing y-harness, you can get the flaps to work independantly of the ailerons, BUT- you cant have the flaps follow the ailerons for more roll. Also, your throws, for some reason, were cut in half. Probably some default program to keep from running the servos to their limit. Potentially, you could max out the throws mechanically, run flaps only, and max the throws, but it can only be described as a kluge.
My suggestion is similar to aarons-find a clean used JR783, or 8103. I've seen those TX's for under $200 bux used. They can do all the oddball mixes you can think of.
slopemeno is offline Find More Posts by slopemeno
Old May 17, 2006, 10:23 PM
droydx is offline
Fun ain't cheap!
droydx's Avatar
Joined Apr 2003
Yeah,
like I say, I already have a Stylus, which is my primary transmitter. I'd like to send it in for some tune up work, and it looks like my "simple model" Optic, will be limited to just that.
I thought there might be some work around to link the flap movement to the ailerons.
THX!
Andy
Old May 18, 2006, 10:39 AM
timmig is offline
Find More Posts by timmig
timmig's Avatar
Southern California
Joined Sep 2003
You need to use the Eclipse 7channel for true crow mixing with aileron coupling. The Optic uses a y on the flaps channel-- so you can get crow-- but not coupling.
FYI
Timmig
timmig is offline Find More Posts by timmig
Discussion Optic 6: "Idle On" warning for plane?? Bigster Hitec/Multiplex USA 7 Aug 02, 2006 07:46 PM
Optic 6 w/ synth on sale at hobbypeople.net for $140!!! Fiasco Radios 0 Jun 01, 2005 04:26 PM
Programming Eclipse TX for flaps on ch 4? Newberry Radios 0 Feb 06, 2005 10:58 AM
Berg 5 and Optic 6 compatibility issues on my Shogun dartbrandx Radios 12 Jan 28, 2005 12:38 AM
Hitec Optic 6 Manual available on the web aeajr Radios 0 Aug 08, 2004 10:11 PM
