Old Apr 16, 2015, 01:02 PM
Strussen is offline
Find More Posts by Strussen
Joined Mar 2012
Which camera? PAL or NTSC
I'm planning to build a 250 FPV Racer, but I don't know which camera to choose.. I've found these 2:
http://www.hobbyking.com/hobbyking/s...F1_2_PAL_.html
http://www.hobbyking.com/hobbyking/s...1_2_NTSC_.html
What's the difference between them? PAL and NTSC? Which on would YOU choose?
Thanks 😊👍✈️
Strussen is offline Find More Posts by Strussen
Old Apr 16, 2015, 01:29 PM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
Those are analog video standards for different countries. Your profile does not specify where you are located so no way to make a recommendation.
RC Man is online now Find More Posts by RC Man
Old Apr 16, 2015, 01:33 PM
Strussen is offline
Joined Mar 2012
I live in Denmark, but does that care when I'm going to use it as FPV?
Old Apr 16, 2015, 02:29 PM
DanT is offline
Find More Posts by DanT
DanT's Avatar
San Angelo TX.
Joined Feb 2006
YES...
One reason ,,, lets say, you want to take your ? goggles ? or what every your using for a ( Receiver ...) and you want to setup your Receiver or Monitor to play your video from Camera on it?? Or TV ??
It won't work if it's not what ever your country uses???
DanT
Tip ,, those cameras your looking at?
You do know they both take 8.5 volts or more to run?
Another tip,, there are lot better cameras out there...!
A board camera like those with no case on them? Bad idea IMO
DanT is offline Find More Posts by DanT
Old Apr 16, 2015, 04:06 PM
Strussen is offline
Joined Mar 2012
Thanks DanT,
I'm planning on using a monitor.
Have anyone got any idea for a better camera?
Old Apr 16, 2015, 05:05 PM
DanT is offline
DanT's Avatar
San Angelo TX.
Joined Feb 2006
Thanks DanT,
Check this one out.
http://www.surveilzone.com/DC5V-plas...m-lens-for-fpv
I use one on my Quad and works good IMO.
DanT
Old Apr 16, 2015, 11:22 PM
John Snow is offline
Find More Posts by John Snow
Joined Aug 2014
Effio-V camera is best for now, but has about 100ms latency, if you do not care about it, choose HS1182, trust me, or you can choose DanT' recommend.
John Snow is offline Find More Posts by John Snow
Old Yesterday, 04:55 AM
United States
Joined Feb 2001
PAL
I have a couple of the HS1182 cameras. They have by far the best picture quality of anything I have seen. That Sony sensor and chip set are definitely the best for FPV.
http://www.surveilzone.com/sony-doub...um-case-HS1182
New Product Emax 1/3-inch CMOS PAL / NTSC FPV Video Camera ohmgnohm FPV Racing 5 Jan 21, 2015 02:59 PM
Discussion Emax 1/3-inch CMOS PAL / NTSC FPV Video Camera ohmgnohm FPV Equipment 0 Jan 04, 2015 11:04 AM
Found Emax 1/3-inch CMOS PAL / NTSC FPV Video Camera ohmgnohm Aircraft - Electric - Multirotor (FS/W) 0 Jan 04, 2015 11:00 AM
Discussion FPV camera Pal or NTSC.. Does it matter ??!! khaled_abobakr FPV Talk 13 May 13, 2011 04:24 PM
Discussion PAL/NTSC, is it camera, or TX/RX? backin FPV Talk 2 Nov 06, 2009 07:03 PM
