Old Apr 15, 2015, 08:35 AM
psywarnco is offline
Find More Posts by psywarnco
Joined Apr 2015
Battery for FPV TX
I have an F450 Flamewheel using Naza M V2 and Zenmuse H3-3D gimbal. My flight battery is a 5200 4 cell. I am installing FPV on this and need power for the FPV TX. It is an Immersion RC 5.8 unit and has its own 5V out. The only thing shown in the crappy instructions is drawing power from the flight battery pack. Will a 4 cell be too high a voltage for this transmitter?
psywarnco is offline Find More Posts by psywarnco
Old Apr 16, 2015, 12:21 PM
Dragon_Nutz is online now
Find More Posts by Dragon_Nutz
Joined Dec 2013
Looking at the specs on the 600mw unit, it can handle 2S-6S (6V-25V) input power. The 5V output is going to be to power your 5V camera. If you're using a 12V camera, you'll need to add a 5V-12V step-up between the vTx and the camera.
Dragon_Nutz is online now Find More Posts by Dragon_Nutz
Old Apr 16, 2015, 01:33 PM
Merkyworks is offline
Find More Posts by Merkyworks
Joined Jun 2013
Is there a concern with voltage/current interference effecting the vTX/camera signal if you run it off the motor/ESC 4s battery? Or is it better to have a separate 3s battery to power the vTX/camera?
Merkyworks is offline Find More Posts by Merkyworks
Old Yesterday, 09:50 AM
Joined Dec 2013
I'm by no means an expert on this, I'm still learning lol. But I believe it all depends on your setup. Test the system (with props off) through your throttle range while looking at the monitor and see if you have a clean image. If you do, you may need to add a power filter to supply clean power to everything. A separate battery is ok as well, but it adds more weight. Also double check that your frequency matches on your vTx and vRx.
Old Yesterday, 10:26 AM
Hajile is offline
Find More Posts by Hajile
Philippines, Calabarzon, San Pedro
Joined Jul 2012
You use a power filter. The ones at hobbyking are always out of stock so i ended up making my own
Anyway, it will depend on your setup. My first ESCs were hobbyking plushies, they worked perfectly. When they burned out, i got Afros, the noise was so bad my OSD had trouble locking on to the signal That's when i installed the power filters.
Try it first tho, your ESCs may not be as noisy, and the higher end vTX (fatshark,immersion,etc.) should have filters built in that can handle most of it, see if there's noise showing up on your video.
Also, testing with the props off is a good start, but the seemingly faint noise may get worse once the motors are under load, so don't go zooming off just because it looked clear on the bench test
Hajile is offline Find More Posts by Hajile
Discussion Hubsan X4 H107D FPV Antenna & TX Battery Mods superjon Mini Multirotors 38 Apr 12, 2015 09:38 PM
Sold DSMX DX8 TX with 4000 ma lipo tx battery for $155.00 read below crosby Aircraft - General - Radio Equipment (FS/W) 11 Dec 12, 2014 01:43 PM
For Sale FPV Lot Cameras, TX RX 1.3, Bluebeam, Batteries, and More elitegunslinger FPV Equipment (FS/W) 3 Oct 13, 2014 10:47 AM
Sold FatShark AttitudeSD FPV System w/5.8 TX, Battery Included Pushjerk FPV Equipment (FS/W) 8 Jan 14, 2014 04:48 PM
Sold FPV Mushroom Antennas for 5.8ghz FPV RX TX aerial RP-SMA for RC plane Antwnis Aircraft - General - Radio Equipment (FS/W) 1 Oct 30, 2013 10:32 PM
