Old Mar 22, 2015, 09:51 AM
dirtyballs is online now
Find More Posts by dirtyballs
Netherlands
Joined Oct 2010
Mini-HowTo
Oculus Rift FPV flying with Meegopad T01
Oculus Rift (DK1/DK2) FPV flying with Mini PC
source and the binaries of the linux application can be found here
What do you need to make this work
- Meegopad T01
- video grabber linux compatible I tried
- easy cap ( STK1160 ) faster then the chvideocr around 40 msec (1 frame )
- chvideocr ( Conexant CX23103 ) is slower but has better sync control ,so less dropped video link
seems that CSUSBVG100 from konig is the same.
- 4 port mini USB 2.0 Hub.
- female to female HDMI converter
- for powering the Oculus usb to 5.5 barrel cable
- power bank with a 2.1 A and 1 A connection I use the Konig 7800 mAh. ( no that good )
you could also make the power bank your self especially if you need
high voltage for your receiver. then use an BEC to create 5 V
The rest is receiver specific
- I used a USBto 3.5 barrel cable to power my modified RC305. USB will only deliver 5.0 volts.
Start with he Backup, it for your safety
Manual for backup of your Meego : here
Manual for Install of the Oculus image :Here
Bart.
dirtyballs is online now Find More Posts by dirtyballs
Old Mar 22, 2015, 09:56 AM
Netherlands
Joined Oct 2010
I placed the manual ( see first post ) I will use the first post to had every status data.
It for now is only the backup of the Meego.
Let us first check if people can do this. It are a lot of steps but
I tried to write it in such away that every body can do it.
This will not touch the Meego and is 100% save.
Bart,
Old Mar 22, 2015, 02:37 PM
ninfivfo is offline
Find More Posts by ninfivfo
Joined Apr 2012
Can I get a list of all items needed to complete the build, sorry if I missed something in the previous posts. What is the list of items you are using for example?
ninfivfo is offline Find More Posts by ninfivfo
Old Mar 22, 2015, 02:40 PM
Netherlands
Joined Oct 2010
Good observation, I will add to the first post
Bart
Old Mar 22, 2015, 05:40 PM
DBA-FW is offline
Find More Posts by DBA-FW
Fort Worth, Texas
Joined Nov 2002
Subscribed!
DBA-FW is offline Find More Posts by DBA-FW
Old Mar 24, 2015, 03:26 AM
aquabait is offline
Find More Posts by aquabait
Joined Aug 2014
Very good work
Subscribed
I have oculus drift2 and I will try to get it on fpv with osd
aquabait is offline Find More Posts by aquabait
Old Mar 24, 2015, 05:05 AM
tecra is online now
Find More Posts by tecra
tecra's Avatar
United States, CA, San Diego
Joined Jun 2013
Great work! Really like the low latency! Any plan to use the internal head tracking to output ppm for pan tilt?
tecra is online now Find More Posts by tecra
Old Mar 24, 2015, 06:11 PM
Netherlands
Joined Oct 2010
Went flying to day and I can confirm now that Conexant CX23103, is the better choice. even with moderated noise I didn't loose the image .
the Konig power bank is not that good 30-40% discharge it can't Handel the current anymore when the full image is white ( oled display ).
So I will make my own power bank with a lipo and a bec.
Bart,
Old Mar 29, 2015, 04:21 PM
MGeo is offline
Find More Posts by MGeo
MGeo's Avatar
New York
Joined Nov 2003
Hi Bart,
I'm in the process of downloading files per the install guide.
Do you have a link you could share for a Conexant CX23103 based grabber on ebay or Amazon?
George
MGeo is offline Find More Posts by MGeo
Old Mar 29, 2015, 05:49 PM
Netherlands
Joined Oct 2010
the one that I bought is only sold in europe :-(
here is a list of Video grabbers that use the chip
http://linuxtv.org/wiki/index.php/Conexant_CX2310x
tried to find one for you but I think it will be a gamble.
I will look tomorrow, need some sleep now
this one is low risk that I see now
EzCAP USB Video Capture Pro
it as more inputs, YPbPr, so not easy to fake,
Bart,
Old Mar 29, 2015, 08:23 PM
MGeo is offline
MGeo's Avatar
New York
Joined Nov 2003
Ok thanks for looking Bart. I have EzCap I'll start with that.
Best Regards,
George
Old Mar 30, 2015, 05:34 AM
Netherlands
Joined Oct 2010
To clarify a little bit the EasyCap, EZCap, easierCap.
These 3 can have the same chip set.
But for instances the EasyCap is already made with 4 different chip sets. And one of them is not directly supported by Linux.
http://linuxtv.org/wiki/index.php/Easycap
I have now the STK1160 EasyCAP compatible .
I still want to try Empia EasyCAP and the Somagic EasyCAP
Bart,
Old Apr 02, 2015, 04:06 AM
MGeo is offline
MGeo's Avatar
New York
Joined Nov 2003
Hi Bart,
I've been trying to download the multiple files from baidu service but am having multiple download failures with this service. Still trying. I'm finding the Chinese dialog boxes tough to navigate upon errors.
George
Old Apr 02, 2015, 08:35 AM
BURDAUG is offline
Find More Posts by BURDAUG
Joined Mar 2013
I can't dounload either
BURDAUG is offline Find More Posts by BURDAUG
Old Apr 02, 2015, 03:36 PM
Netherlands
Joined Oct 2010
Both backup and install manual are there now.
In the Backup manual you can find a new download link. if everything is ok, then within 24 hours all files can be found there.
I am also going to make an ISO that you can put on a USB, and then boot from that USB. So you don't need to update the Meego.
Bart,
News 3D FPV with Oculus Rift Jason Cole FPV Equipment 14 Mar 19, 2015 04:15 PM
Sold Oculus Rift with a Transporter 3D FPV setup rimb05 FPV Equipment (FS/W) 1 Mar 04, 2015 10:32 AM
Discussion New RC-Flight simulator - FPV with Oculus Rift support. khos85 FPV Talk 11 Feb 19, 2015 11:16 AM
Discussion New RC-Flight simulator - FPV with Oculus Rift support. khos85 Simulators 1 Jan 04, 2015 01:03 PM
Discussion Oculus RIFT - the next generation of FPV goggles? the_cloud FPV Talk 4 Jun 08, 2012 05:41 PM
