Old Dec 30, 2014, 03:47 PM
G Norsworthy is online now
Find More Posts by G Norsworthy
Master of the Wind
G Norsworthy's Avatar
United States, CA, San Jose
Joined Sep 2008
Build Log
2 Piece Pickle
Doesn't everyone wish they had a 2 piece Pickle? One they could take apart and carry anywhere they want? Then put it back together and fly it when the time and place is right? Noel and I have been kicking this idea around for a bit and we finally had a window of time and brain bandwidth to get moving. This one won't be Skinny, rather a stock 2 panel Edge wing from the last batch. Great care will be paid to attention to detail so that this one flies absolutely as well as possible for a homebuilt model.
G Norsworthy is online now Find More Posts by G Norsworthy
Old Dec 30, 2014, 05:34 PM
Master of the Wind
Joined Sep 2008
We are basically following the Oleg 2 pc Taboo style build but with the angle cut. We started with carbon tubes and used vaseline and release film to lay up outer concentric tubes over these.
The layout for the wing was drawn using a sharpie and the slots for the outer tubes were routed and cut.
Then the outer tubes were glued in the slots, one piece to be cut later when we cut the wing.
Old Dec 30, 2014, 06:06 PM
JimZinVT is offline
Find More Posts by JimZinVT
let's FLY!
JimZinVT's Avatar
United States, VT, Castleton
Joined Dec 2007
JimZinVT is offline Find More Posts by JimZinVT
Last edited by JimZinVT; Dec 30, 2014 at 06:10 PM. Reason: I don't want a pickle....I just want to ride on my motorcicle :-)
Old Dec 30, 2014, 07:15 PM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
This is a great idea Greg. Two piece wings will be more common as airlines get more stingy with baggage.
tom43004 is offline Find More Posts by tom43004
Old Dec 30, 2014, 07:55 PM
M Seid is online now
Find More Posts by M Seid
M Seid
M Seid's Avatar
Solana Beach, Ca
Joined Sep 2006
Nice thread title! The title alone sets a very high bar for the plane.
M Seid is online now Find More Posts by M Seid
Old Dec 30, 2014, 08:25 PM
sporter is online now
Find More Posts by sporter
Come out swinging
sporter's Avatar
San Diego
Joined Mar 2005
Ha!
sporter is online now Find More Posts by sporter
Old Dec 30, 2014, 10:25 PM
samc99us is offline
Find More Posts by samc99us
Aurora Builder
United States, MD, Lusby
Joined Nov 2003
This is neat Greg. +1 to Mike.
Following with interest-implementing into a solid core molded wing should be doable at low weight penalty.
samc99us is offline Find More Posts by samc99us
Old Dec 30, 2014, 10:42 PM
tom43004 is offline
tom43004's Avatar
Joined May 2002
Sam... hush!
Old Jan 01, 2015, 03:21 AM
Master of the Wind
Joined Sep 2008
Made some progress today. Got the spar channels routed out and the spars glued in. Made the tubes for the wing posts. Be ready to bag shortly. Then start on the tails.
Old Jan 01, 2015, 02:13 PM
Noel Eberhardt is offline
Find More Posts by Noel Eberhardt
Cupertino, CA
Joined Dec 2008
Here are other photos (somewhat belated) from the building process.
Working with Greg on this project has been and is a rewarding learning experience beyond "stick-n-tissue" building. We're enjoying this winter building comfortably inside on a flat maple table and our long, flat granite kitchen island when it's too cool in the garage. Greg is an experienced long-time student of model aviation generous in sharing as well acknowledging and giving credit to other's contributions and developments.
Noel Eberhardt is offline Find More Posts by Noel Eberhardt
Old Jan 01, 2015, 02:57 PM
Cupertino, CA
Joined Dec 2008
Wing attachment tubes
Using the same technique as making the joiner tubes, we made the wing mounting tube. Perhaps this series of photos gives a little more detail on Greg's precision tube fab technique. This photo sequence shows the unwrapping after the epoxy cured, i.e., the reverse of the assembly.
Old Jan 01, 2015, 09:00 PM
JimZinVT is offline
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
Can you elaborate slightly on the joiner tube / wing tube process? (or maybe it's been explained in another thread?) From the photos, I'm seeing Glad wrap as release film (over Vaseline?), roll on the wet carbon (uni? weight?) and wrap with electrical tape (backwards?). Is that about right?
- Jim
Old Jan 01, 2015, 10:54 PM
Master of the Wind
Joined Sep 2008
Tube rolling
The tubes are made by starting with the actual inner tube as a form.
Then vaseline to allow it to release.
The wrap about 2 wraps of Accuply 10 release film over the vaseline and tape the ends with blue masking tape.
http://www.accuply.com/accuply10.html
Call them and tell them you are setting up a laminating line and would like a sample of their material. They will send you a small roll that will last years. They don't really sell in small quantities.
Always in the same direction wrap the carbon cloth. Uni works well because it bends easily in the rolling direction.
Finally follow with the electrical tape. You want the stretchy kind, and pull it as tight as you can. Epoxy should ooze out of the edges. Once it is kicked the whole thing should release fairly easily. The fit will be really tight.
Old Jan 02, 2015, 05:03 AM
JimZinVT is offline
let's FLY!
JimZinVT's Avatar
Joined Dec 2007
Thanks Greg!
Wanted Blaster 2E 2 piece or 1 piece wing mylestone Aircraft - Sailplanes (FS/W) 0 Nov 07, 2014 07:06 PM
Wanted Looking for a good two piece Deans whip antenna(must be 2 piece 72/75mhz) HyperHelis Aircraft - General - Radio Equipment (FS/W) 4 Feb 20, 2010 07:51 AM
Discussion F3B Wings Why are they 2 piece and not 3 piece? soholingo Multi Task F3X 33 Jan 27, 2009 03:58 AM
Discussion 1-piece to 2-piece V-tail conversion Phil.Taylor Slope 2 Sep 01, 2008 10:06 AM
Dean's 2-piece or 1-piece antenna???? kenmalecki Electric Heli Talk 10 Nov 12, 2005 10:37 PM
