Old Jan 12, 2014, 01:43 PM
SoulB is offline
Find More Posts by SoulB
Joined Dec 2013
Bought 4S by mistake. Should I just return?
Ordered some more batteries from HK and got 4S rather than 3S by mistake.
Was going to send them back but before I do is there any reason why I can't use them?
I've got a HK2.1 FC, 30A Turnigy Plush ESCs, and 1100KV Turnigy motors.
What would happen if I use a 4S battery?
I've also got some LEDs attached with a 3S balance plug connector to power them. Assuming I can get an adaptor would they blow on a 4S?
SoulB is offline Find More Posts by SoulB
Old Jan 12, 2014, 02:06 PM
SoulB is offline
Joined Dec 2013
Hmm on the HK page for my motors it says
Prop size: 7.4V/11x7 14.85V/7x3
So I guess on a 4S pack I should be using 7" props? Given I'm running 9" then using a 4S pack would be a bad idea?
Old Jan 12, 2014, 02:09 PM
LoneStriker is offline
Find More Posts by LoneStriker
Joined Oct 2013
Check if your ESCs support 4s. Running 4s might be less efficient for your particular build, but I'm guessing it'll fly. As for the LEDs, not sure. Again, check what voltage they'll support.
LoneStriker is offline Find More Posts by LoneStriker
Old Jan 12, 2014, 02:12 PM
SoulB is offline
Joined Dec 2013
They will take 4S packs. However won't my motors draw too much current at 14V with 9" props perhaps?
Old Jan 12, 2014, 02:16 PM
Joined Oct 2013
Look for the datasheet for your motor with various prop sizes and battery voltage.
Old Jan 12, 2014, 02:28 PM
SoulB is offline
Joined Dec 2013
Hmm the datasheet that came with the motor says 7.4-11V in the Volts column for all options, but then in the Battery/Prop column says
LiPox2/2x6
LiPox4/9x6
for D2836-8
Seems pretty contradictory that it says 11.1V as max voltage but then says what props to use on a 4S pack (which oddly seems to be 9" which I have).
Old Jan 12, 2014, 04:15 PM
SoulB is offline
Joined Dec 2013
Am I right in thinking that the change in power from the motors would mean needing to re-setup all my FC settings?
If so then using the same quad on a mix of 3S and 4S packs would quickly become quite annoying...
Old Jan 12, 2014, 05:21 PM
Joined Oct 2013
The different 3s vs. 4s settings in your FC would mostly be in the gains (if you're flying Naza) or the PIDs for APM/Multiwii/KK2). It shouldn't be much different and you should be able to fly with the 3s settings just fine.
Old Jan 12, 2014, 05:28 PM
SoulB is offline
Joined Dec 2013
Hmmmm interesting thanks. Read another thread with some guy who tried a 4S and his quad immediately started oscillating etc.
Old Jan 12, 2014, 05:33 PM
RC_Flying is offline
Find More Posts by RC_Flying
United States, NJ, Edgewater Park
Joined Dec 2013
You might have to adjust your PID's,otherwise you will be fine. I run 3S and 4S on my quad and tricopter and while my tricopter is fine,my quad has some oscillations on 4S,but much more power. You might buy some more 4S after you fly with it.
RC_Flying is offline Find More Posts by RC_Flying
Old Jan 12, 2014, 06:19 PM
TheQuestor is online now
Find More Posts by TheQuestor
Official Stupid Question Asker
TheQuestor's Avatar
United States, TX, San Juan
Joined Mar 2013
4S should be fine on everything but the LEDS. They will run REALLY HOT @ 16 volt which is what your 4S charge to. The 3 cell charge to just over 12 v which is what your leds are set for.
What I do is run a DC-DC Buck step down converter to my LEDS so they run cool and don't get the backing hot enough to pull off which they did a LOT before I used the buck converter.
I bought a boat load of these
http://www.ebay.com/itm/130984316514?
they come in really handy as you can adjust them to whatever output voltage you need
TheQuestor is online now Find More Posts by TheQuestor
Latest blog entry: QTipToo.8 Part 5
Old Jan 13, 2014, 02:48 PM
SoulB is offline
Joined Dec 2013
Thanks!
Thinking about it though, if the LEDs run off pins 1 & 4 of the 4pin 3S balance plug couldn't I just modify the plug so I can plug them into pins 1 & 4 of the 5pin 4S balance plug?
The pins come from either side of each cell so I'd be getting the same number of volts as I'd only be using 3 cells in effect?
Old Jan 13, 2014, 03:04 PM
TheQuestor's Avatar
Joined Mar 2013
Originally Posted by SoulB View Post
Thanks!
I always ALWAYS fly with voltage alarms connected to my balance plugs so I never have an open one handy But yes in affect you should be able to do that. The red lead goes to the + tab of the 1st cell then a black goes to the - of the 1st cell and + of the 2nd cell then another goes to the - of the 2nd and + of the 3rd etc.
Best way to check is just use a volt-ohm meter
Old Jan 13, 2014, 05:09 PM
SoulB is offline
Joined Dec 2013
I've got a voltage alarm from my KK FC so my balance plug is free. Will check with a multimeter
Old Jan 13, 2014, 07:57 PM
5391337 is offline
Find More Posts by 5391337
Joined Sep 2013
I don't think it's a good idea to discharge a battery from only part of the cells on a balance plug. Even if you do, you must balance charge it every time or risk a fire or worse...
5391337 is offline Find More Posts by 5391337
Discussion bought my first eflite plane, what should i get next TonyTheAsian Electric Plane Talk 3 Dec 27, 2013 11:39 PM
Discussion Just bought a Protech PT80 carlbrid Jet Turbines 3 Oct 06, 2013 08:57 AM
Careful! Bought #12 Keychain Spycam by mistake DrFragnasty Aerial Photography 1 Aug 17, 2011 07:04 AM
Discussion Just bought a 36v A123, but it seems really old--should I return it? JWilliams2 Batteries and Chargers 7 Feb 08, 2008 05:22 AM
Discussion just bought Brio 10, think i made a mistake berettafan Electric Plane Talk 33 Jul 24, 2007 10:56 PM
