Old Dec 09, 2013, 02:14 PM
sgmxr6 is offline
Find More Posts by sgmxr6
Duck tape cant fix that
United States, TN, Nashville
Joined Sep 2012
Aircore corostar
So here's the deal fellas I've got tbis corostar by aircore I'm sure most of the spad guys remember these The long and short of it is I want to add flaps to the wing for training myself to get use to using them and mixing them with the elevator.
I was told by someone I don't know it would be too expensive?
I'm not really certain how as I have tons of coroplast and servos as well as a radio to handle the mixing.
Can someone chime in here please .Thanks guys.
sgmxr6 is offline Find More Posts by sgmxr6
Old Dec 09, 2013, 04:30 PM
aspeed is online now
Find More Posts by aspeed
Canada, ON, Cottam
Joined Jan 2012
I am sure you can program it in on a computer radio. Flaperons? or spoilers? It certainly wouldn't be expensive if you have the right radio, you just have to figure it out, or ask someone who knows.(not me)
aspeed is online now Find More Posts by aspeed
Old Dec 09, 2013, 07:14 PM
sgmxr6 is offline
Joined Sep 2012
Thanks airspeed I can do flaperons I'm just not sure if I can dial them in mid flight.That's why I wanted to just add them to the plane.I have measured my area where the flaps shoul be and I have several inches to work with.I will put a picture of the unbuilt wing half up so you can see it.
Old Dec 09, 2013, 07:16 PM
sgmxr6 is offline
Joined Sep 2012
Old Dec 09, 2013, 07:17 PM
sgmxr6 is offline
Joined Sep 2012
Old Dec 09, 2013, 07:23 PM
sgmxr6 is offline
Joined Sep 2012
If you look closely I marked the wing wrap line onto the wing.From there to tbe aileron is 8 1/2 inches I was thinking maybe a 6 inch flap?
I don't know if I will be upsetting anything or if just cutting out The wing similar to the aaileron will be ok.
Its not the process of building it thats the issue its my lack of aerodynamic knowledge.
Old Dec 09, 2013, 08:16 PM
Canada, ON, Cottam
Joined Jan 2012
I would just do it in one piece, and program in the flaps. I have never done that though so maybe someone else could chime in.
Old Dec 09, 2013, 08:42 PM
sgmxr6 is offline
Joined Sep 2012
But with flaperons don't you lose all your aileron control ?
Old Dec 10, 2013, 06:50 AM
Extreme Sports is offline
Find More Posts by Extreme Sports
Extreme Sports's Avatar
South Africa, GP, Johannesburg
Joined May 2012
I've been doing some experimenting with flaps on correx planes. I personally don't like flaperons - while you don't lose all aileron control, my experience is that you definitely lose some at full flap extension. Given that, for the small cost of one extra servo, you can have independent flaps, my view is that normal (independent) flaps are the better option.
I'd make the flaps the full span of the gap between the doubler and the existing ailerons (i.e. just leave a ~2mm gap so that there is no binding). Have the flaps set up to use the same hinge line as the ailerons - this way the airfoil profile will remain the same across the wing.
See attached pics of the flaps on two of my wings - should be clearer than the description above. In both cases the flaps really help landing performance
BTW, not quite sure what you mean by 'mixing them with the elevator' unless you are referring to an elevator mix to compensate for any nose up/down pitch that could accompany flap deployment
Extreme Sports is offline Find More Posts by Extreme Sports
Old Dec 10, 2013, 11:44 AM
sgmxr6 is offline
Joined Sep 2012
Thanks Extreme,
Very nice mustang really scaled nicely best example Ive seen.!
Question Aircore corostar sgmxr6 SPAD - Simple Plastic Airplane Designs 54 Nov 14, 2013 08:50 AM
Sold U.s.aircore barnstormer 40 kstrojny Aircraft - Fuel - Airplanes (FS/W) 0 Oct 04, 2013 12:51 PM
Question Aircore corostar sgmxr6 SPAD - Simple Plastic Airplane Designs 0 Oct 09, 2012 02:29 PM
Sold us aircore corostar II squirrel40 Aircraft - Fuel - Airplanes (FS/W) 2 Oct 18, 2010 07:38 PM
