Old Dec 05, 2013, 02:31 PM
BigStick63 is offline
Find More Posts by BigStick63
United States, NH, Amherst
Joined Aug 2013
Rascal 40 Convert
Looking to convert a Sig Rascal 40 (72" wing) from glow to electric. Tired of the fuel mess and temperament engines. Not having much luck with any 2 cycler installed upside down either. It's a great aircraft otherwise and interested in Plan B.
Reading the threads and my head is about to explode. LOL Any help in powerplant/battery/prop size is appreciated.
BigStick63 is offline Find More Posts by BigStick63
Old Dec 05, 2013, 02:53 PM
Seminole is offline
Find More Posts by Seminole
United States, MN, St Michael
Joined Apr 2010
I am flying the Rascal 72 that is electrified. I'm running a Rimfire 32, Castle 75amp ESC, with a 13x8 prop. I am running anything from a 4s3300 up to 4s 4400. I also have the medium motor mount from great planes...made for the Rim Fire motors.
On 4400 with throtle management and using the wind to glide some, I can fly for nearly 20 minutes.
Depending on battery placement I can even hover it in low winds. Fun plane.
Seminole is offline Find More Posts by Seminole
Old Dec 05, 2013, 08:31 PM
bhchan is offline
Find More Posts by bhchan
Electric Airplane Junkie
bhchan's Avatar
United States, CA, San Mateo
Joined Jun 2000
It started about 10 years ago, here, http://www.rcgroups.com/forums/showthread.php?t=143247 my conversion starts at thread #209 and on....
Motor is AXI 2826/12 on 3S6000(need the nose weight!) on APC 15x8.
Later switch to a 4S4000 and 13x8, less torque from the smaller propeller made the ground handling on take offs mush easier.
The AXI2826/12 has a Kv of 760. I am sure you can find a Turnigy or equal motor much cheaper these days.
Brian, an EAJ
bhchan is offline Find More Posts by bhchan
Old Dec 05, 2013, 11:49 PM
ddemu is offline
Find More Posts by ddemu
United States, ID, Shelley
Joined Dec 2011
See if this helps.
Myself, I would shoot for @100 watts/pound.
ddemu is offline Find More Posts by ddemu
Old Dec 06, 2013, 12:01 AM
bhchan is offline
bhchan's Avatar
Joined Jun 2000
I don't know what watt/pound is on my set up, as I don't weigh my planes!!
Brian, an EAJ
Yippee! Converted a Sig Rascal 40 to electric Xpress.. Glow to Electric Conversions 79 Sep 26, 2009 10:11 AM
Found Plans: Rascal 40, and Rascal 49" P-6e Aircraft - Fuel - Airplanes (FS/W) 4 May 18, 2006 06:14 AM
Found Wanted - Plans: Rascal 40, and Rascal 49" P-6e Aircraft - Electric - Airplanes (FS/W) 1 May 17, 2006 01:40 PM
Found Plans: Rascal 40, and Rascal 49" P-6e Aircraft - General - Miscellaneous (FS/W) 2 May 17, 2006 08:59 AM
Help! Looking to convert a Rascal .40 stafphoto Glow to Electric Conversions 1 Feb 23, 2006 05:04 PM
