Old Oct 03, 2013, 12:50 PM
terry c is offline
Find More Posts by terry c
Joined Oct 2013
new to footy's
I'm new to rc sailing and I have a few questions.
IM building one from a door skin and was wondering how tall the mast should be. All parts I want to make myself,I was going to make the mast from bamboo wrapped with butcher twine. I was wondering about what type of sail setup I should use. and lastly how to set up the servos. Any help would be appreciated. thank you all for a wonderful forum.
terry c is offline Find More Posts by terry c
Old Oct 03, 2013, 02:09 PM
tarmstro is online now
Find More Posts by tarmstro
RC Newbie with lots of ideas
Chile, Santiago Metropolitan Region, Stgo
Joined Dec 2012
Take a look at my work on Footy's here. Bottom pictures show the build process:
http://www.flickr.com/photos/thomasa...7634084768525/
If you need help/info/measurements please ask me here.
tarmstro is online now Find More Posts by tarmstro
Old Oct 03, 2013, 03:28 PM
terry c is offline
Joined Oct 2013
thanks for the very nice pics that helps me with the servo set up, I'm still not sure about the mast and boom
Old Oct 03, 2013, 07:31 PM
Joined Dec 2012
My mast is made from 3mm carbon fiber rods (solid, not tubes!). The z-wire is made from a bicycle wheel wire, bent in anglesand cut to lenght.
I attached the rods to the wire using some strong synthetic string, glued toghetes with AC-glue, and then some thermo-contractible plastic for protection and finish.
Old Oct 04, 2013, 03:54 AM
Phil 42 is offline
Find More Posts by Phil 42
Joined Sep 2013
I would have a look at the wealth of Footy related info at:
http://www.sailfootyuk.com
If you look under the 'Footy Types' and 'How to' tabs there is a range of tips covering hulls and rigs.
Phil 42 is offline Find More Posts by Phil 42
Old Oct 04, 2013, 04:25 AM
Phil 42 is offline
Joined Sep 2013
Sorry, forgot to mention in the other post :
My home made 'una' rigs for SUI 42 are constructed from:
4mm dia carbon tube for the mast and aft boom section
5mm dia Alu tube for forward boom section
3mm Alu tube for the mast stub and mast pivot
3mm Alu rod turned on a lathe for the pivot point. Even a short pice cut from a paper clip and rounded at one end will do fine and is much easier.
Larger sails use 23 micron film and smaller sails use 36 micron film
A max mast length of 750mm and a total boom length of 420mm forms the basis of my largest sail which fits the experimental rig template used in the UK to limit max sail size for regattas.
For more general cruising, a mast of 600ish mm and a total boom length of 340ish mm would probably be more appropriate.
Last edited by Phil 42; Oct 04, 2013 at 04:29 AM. Reason: 2nd post submitted arrived on the forum before 1st post !
Old Oct 04, 2013, 06:52 PM
Yellow Baron is offline
Find More Posts by Yellow Baron
0.9g retracts
Yellow Baron's Avatar
3" from insanity, 2' from the computer ,Richford, Tioga county, Southern Tier, New York, U.S., North American Continent, Northern hemisphere, Earth, The Sol System, Milkyway Galaxy, The Universe, The Current Dimension, Your Selected Realm of Reality.
Joined Dec 2006
I make my masts from 1/4-3/8" spruce depending on the size, and the booms from 1/8-3/16". As far a height, it really depends on what type of rig you want, I've done everything from 12- 22"; cat boats, modern sloops, and gaff rigged cutters.
A few threads of mine, covering my first foray into footys through one of my later documented builds.
http://www.rcgroups.com/forums/showthread.php?t=1032755
http://www.rcgroups.com/forums/showthread.php?t=1104210
http://www.rcgroups.com/forums/showthread.php?t=1143513
I'm also hoping this winter to do a co-build thread on a pair of boats with my fiancee, mine will be a mostly scale Cape Henry 21 with a gaff rig, or something similar if I change my mind.
Yellow Baron is offline Find More Posts by Yellow Baron
Link Footy-Italia.it a new resource for the Footy RC! huzway Sailboats 1 Aug 02, 2013 01:04 PM
Discussion Footy-Italia.it a new resource for the Footy RC! Seantiago Dock Talk 0 Jul 25, 2013 11:54 AM
Discussion New sailboat builder with two footies on workbench. Frye Sailboats 9 May 30, 2013 02:26 PM
Discussion First Footy, Razor 3 gettinout Sailboats 2 Feb 12, 2013 11:56 AM
Discussion Victor V 12 Footy question dwatson Sailboats 6 Feb 05, 2013 09:01 AM
