Old May 26, 2014, 04:26 AM
Brandano is online now
Find More Posts by Brandano
You could try and see if a thrust augmenter will work. You are picking up the airflow right behind the impeller, maybe there's some pressure that can be traded for air volume.
[edit] This is what I mean:
Brandano is online now Find More Posts by Brandano
Old May 26, 2014, 06:00 AM
cupsster is offline
Find More Posts by cupsster
ninja's fly low
Slovakia, east
Joined Jan 2009
Cnograts on progress. Keep up good work. That ejector loos nice as well. Just use similar profile as on normal wing with more curved face inside ejector.
cupsster is offline Find More Posts by cupsster
Old May 28, 2014, 01:27 PM
Joel_Vlashof is offline
Find More Posts by Joel_Vlashof
Joined Nov 2012
details
working on some nice detail
Joel_Vlashof is offline Find More Posts by Joel_Vlashof
Old May 28, 2014, 01:33 PM
Joined Nov 2012
I also started in Solidworks to redesign the 3 bearing swivel module. this one wil come in Black the ailron nozzle pipe wil be longer for stronger controll. more wing profile in the duct. and try something whit that enjector. Brandano many thanks for youre support. again sorry for my poor english:P
Old May 28, 2014, 01:46 PM
Joined Nov 2012
some project foto's
Here are some project foto's and a little sneek peak inside the jet. total flying weight is now2830gram. you can see the 90mm duct the 70mm duct.
Old May 28, 2014, 06:23 PM
v22chap is online now
Find More Posts by v22chap
v22chap's Avatar
United States, IN, Granger
Joined Jan 2003
it must be nice to have a 3 D printer and know how to use solid works
Don't worry about your English it is far better than any attempt that I would make at your language !!!!
It finally hit me as to how you are controlling the duct rotation --- very , very clever and simple ......
Great job ,,,, keep up the great work
v22chap is online now Find More Posts by v22chap
Old May 29, 2014, 03:33 AM
meerkat13 is offline
Find More Posts by meerkat13
meerkat13's Avatar
United Kingdom, Birmingham
Joined Jan 2013
Awesome engineering Joel!
meerkat13 is offline Find More Posts by meerkat13
Old May 29, 2014, 06:44 AM
The first and the last segments are linked to each other right? so that it only takes two servos to get the duct to rotate. It could be made to bend with a single servo, but then it would lose the option to control yaw in the hover
Old May 31, 2014, 04:41 AM
Joined Nov 2012
that' s right. i just need one sailwich to rotate the duct. and i used one servo for the yaw in a hover. 2 different pylons on the sailwins. one for the 90 degree turn and one pylons for 180 degree turn.
Old Jun 06, 2014, 05:07 PM
Rocketman1092 is offline
Find More Posts by Rocketman1092
Purdue Engineering
Rocketman1092's Avatar
United States, CA, San Diego
Joined Jan 2005
Joel, would you mind describing the mechanics of your swivel duct design? It's the only one I've seen that doesn't have servos inside the duct, which is very impressive.
Rocketman1092 is offline Find More Posts by Rocketman1092
Old Jun 13, 2014, 01:11 AM
nymadcientist is offline
Find More Posts by nymadcientist
United States, NY, New York
Joined Sep 2012
Joel_ vtol
Originally Posted by Joel_Vlashof View Post
I Agree This is not easy, Total weight is now 1602 gram. and I got 2356 gram of thrust in the hover mode. I used 70mm duct in the front. 2 50mm for ailrons and a simple 65mm in the rear. it gives me a flight time of 2,5 minutes on a 3700 4S 45C. I will post fotos of the baering duct. and i will tell you guys more about this project. many thanks for the positive reply's Sorry for my bad english
i have a set up with 70mm puting out 5kg on a 5000 mah i just need a3 bearing swivel duct we can do a trade if u whant to _ and i have a 3d printer and a cnc if u need u can came over my work shop
nymadcientist is offline Find More Posts by nymadcientist
Old Jun 14, 2014, 12:49 AM
Joined Sep 2012
Swivel duct
Like!!!!!!! Many thanks
do u have a Swivel duct file for a 3d printer
Old Jun 16, 2014, 03:59 AM
Joined Nov 2012
3bsm
yep, but it is not for sale. it will be an open source for everyone who want to build an vtol F35 3BSM when this project is finished i am going to release the cad files and build instructions
Joined Nov 2012
X35 rc 3bsm (0 min 56 sec)
Old Jun 16, 2014, 04:27 AM
That is very, very smooth and cool. I still wonder how you managed to get those large rings to slide on each other without jamming. I see you are still using straight duct sections, but since you seem to have plenty of power to spare then probably it's just fine, and maybe a bit easier to print. Nice view of the closed cable loop between the first and last section of the duct.
