Old Jul 07, 2013, 01:38 PM
flytrip is online now
Find More Posts by flytrip
I land when i CFIT!
flytrip's Avatar
USA, UT, Sandy
Joined May 2007
Jw Spar repair
Hey Folks,
I have a light Jw (53oz) that has a broken spar, about 8" from the wingtip.
Feels like a pretty clean break, rest of plane is still in good shape.
Looking for ideas on how to fix the spar without dismantling the whole thing and cutting out the whole spar. If that's the case, I'd rather just buy a new one.
TIA,
Colby
flytrip is online now Find More Posts by flytrip
Old Jul 07, 2013, 04:26 PM
gizzo is offline
Find More Posts by gizzo
gizzo don't tweet
gizzo's Avatar
Adelaide, Australia
I've "fixed" loads of broken spars in foamies. I do it like this: Cut away a strip of covering alongside the spar broken part, the width of a new spar. Dremel out a channel to take a new piece of spar. Glue the new piece in, finish nicely, recover with tape or something. If you broke top and bottom ones, do it twice. The length of the new piece you'll have to decide for yourself. If its a break in the centre of the wing, Id use about 12", out near the tip 5" or 6" will be plenty. My foamies end up riddled with these kind of repairs and the still fly fine. Just keep getting heavier.
gizzo is offline Find More Posts by gizzo
Old Jul 12, 2013, 03:27 AM
Forrest12 is offline
Find More Posts by Forrest12
DS state of origin NSW Vs QLD
Forrest12's Avatar
Joined Jul 2009
And flying faster
Forrest12 is offline Find More Posts by Forrest12
Old Jul 12, 2013, 11:16 PM
Aerogance is online now
Find More Posts by Aerogance
U down with EPP? Ya u know me
Aerogance's Avatar
United States, CA, Ventura County
Joined Sep 2008
I will add to Gizzo's repair tip to double check the tip-to-tip balance of the wing after the repair. It will most likely be off quite a bit so its a good time to balance things out again after major surgery like this.
Aerogance is online now Find More Posts by Aerogance
Old Jul 13, 2013, 05:12 PM
I land when i CFIT!
flytrip's Avatar
USA, UT, Sandy
Joined May 2007
Thanks fellas, got it fixed.
Old Jul 14, 2013, 04:34 PM
grfcon is offline
Find More Posts by grfcon
chronic in training
grfcon's Avatar
L.A. beautiful san fernando valley
Joined Nov 2008
wouldn' t the spar just break again where the new piece...
hits the old spar due to wing loading? or am I missing something?
thanks
grfcon is offline Find More Posts by grfcon
Old Jul 15, 2013, 11:55 PM
DT56 is offline
Find More Posts by DT56
Joined Aug 2005
Originally Posted by grfcon View Post
Wouldn' t the spar just break again where the new piece hits the old spar due to wing loading? or am I missing something?
thanks
Grfcon, I read Gizzo's post as meaning adding a new section of spar alongside the broken original spar; with the new section acting as a doubler. Ideally, the doubler would taper in thickness at its ends to reduce the chance of a stress concentration.
DT56 is offline Find More Posts by DT56
Old Jul 16, 2013, 11:07 AM
grfcon is offline
chronic in training
grfcon's Avatar
Joined Nov 2008
I see it now..didn't catch that the first time. makes sense..thanks for pointing it out.
Help! PH-4 Wing spar repair/replacement FloridaHeli Ornithopters 7 Jun 10, 2013 11:45 AM
Sold JW 60" and extra wing w/triple carbon spar $250 jrbike Aircraft - Sailplanes (FS/W) 2 May 20, 2010 11:00 AM
Discussion Secruing JW spars into joiner Kahnx Dynamic Soaring 10 Feb 06, 2009 09:25 AM
Cool JW 60 with solid carbon spars L2 Airframes Dynamic Soaring 36 Sep 18, 2008 04:46 PM
Repairing a spar Frank B The Builders Workshop 4 Dec 16, 2004 02:54 AM
