Old Jun 27, 2013, 11:56 AM
E-Challenged is online now
Find More Posts by E-Challenged
E-Challenged's Avatar
United States, CA, Garden Grove
Joined Oct 2000
My Cellpro 10S Has Become Unstable
My Cellpro 10S is 3-4 years old and has become unstable with alarms and cryptic random safety codes and error messages that eventually clear by disconnecting and reconnecting balancing adapters, battery packs, crossing fingers and toes, etc., Example Channel 1 No add up, Channel 2 No add up, Safety code 70, etc. It is becoming warm and humid in my garage, is that a possible factor?
I suspect that it is the tiny female connector sockets and male pins on the charger node and balance charge adapters and battery packs have less than perfect continuity. I tried Isopropyl alcohol on pins and sockets, connecting and disconnecting, etc. No real improvement in stability. Don't now how to clean tiny connector sockets effectively other than disconnecting and re-connecting.
Is it time to buy new balance/charge adapters or send the otherwise working charger in for repairs.? It has V2.26 software update installed. I have not opened it up and removed diodes, the fuse between center banana plugs is good per my ohmeter.
PS: I updated software to V2.30 after finding out that V2.26 was not last update for my original 10S charger. Finally remembered that charger needs power supply to download software, etc.(LOL)
E-Challenged is online now Find More Posts by E-Challenged
Old Jun 28, 2013, 12:29 PM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Hi,
The error 70 indicates series switch closure timeout. You could have a coule of blown diodes causing this, D15 & D16. Since the charger is no longer under warranty, I would check these diodes and remove them. No need to replace them as they are now DNI. Let me know how you make out and if you, you can send the charger in for service. Thanks.
Howard Matos is offline Find More Posts by Howard Matos
Old Jun 29, 2013, 06:05 PM
Joined Oct 2000
Where Do I Send It for Service
I opened the charger up, slid circuit board out of heat sink case and saw what looked like tiny diodes but could not read the tiny markings. I decided that the components and markings are too small with my eyesight to attempt to remove them.
Where do I send charger for removal of offending diodes and checkout to resolve nuisance errors and warnings? Should I send balance charge adapters too? Will there be an $80.00 flat fee for service?
Old Jul 02, 2013, 08:28 AM
AR-15 BRD!
Frederick, MD
Joined May 2002
Hi, Please send the unit to 3520 Sugarloaf Parkway, Suite F-03-121, Urbana MD, 21704. There is a flat $60 repair fee which includes the diagnosis, parts, labor, and return shipping as long as you live inside the US. The fee does not cover the microprocessor, which if damaged, is not cost effective to replace. If this is the case, we do not charge the repair fee. Please add a note as to the problem along with a form of payment to expedite the process. Thanks.
Old Jul 15, 2013, 11:18 AM
DonA is online now
Find More Posts by DonA
DonA's Avatar
United States, CA, Placerville
Joined Feb 2006
Originally Posted by Howard Matos View Post
Hi,
A friend has a 10S with the same issues. I located D16 but don't see D15. Where is it located?
thanks
Don
DonA is online now Find More Posts by DonA
Old Jul 19, 2013, 08:34 PM
Joined Oct 2000
Finally sent my 10S in for service, two days ago, hope to get it back soon, my old Hobbico Elite Dual charger can only do up to 3S lipos.
Old Aug 09, 2013, 09:54 AM
Joined Oct 2000
My 10S has been recalibrated and tested charging two test packs and is on its way back.FMA advised that my two balance adapters had worn 3S pack connectors, so I ordered new ones, also on their way. Hopefully charger will be good as new without nuisance error messages and no need for fiddling.
Satisfied Customer: Got charger and new balance adapters. Charger and adapters are working well together, very stable. I think that my old worn balance adapters were largely to blame for error messages, etc.
Old Aug 19, 2013, 09:01 AM
AR-15 BRD!
Frederick, MD
Joined May 2002
thanks
Don
Hi,
D15 is located just below the big cap (C25) and just below the fan.
Old Aug 26, 2013, 08:21 PM
DonA is online now
DonA's Avatar
Joined Feb 2006
Thanks Howard
Don
Old Nov 18, 2013, 05:55 PM
bdp3822 is offline
Find More Posts by bdp3822
bdp3822's Avatar
Honolulu, HI
Joined Jun 2007
I am looking for D16. Where is that one?
Bryon
thanks
Don
bdp3822 is offline Find More Posts by bdp3822
Discussion My Cellpro 10S Charger Is Losing It's Mind. E-Challenged Batteries and Chargers 3 Jun 27, 2013 11:27 AM
Discussion Once Effective, The Tea Party Has Become Toxic Broken Wings Life, The Universe, and Politics 31 Apr 07, 2013 07:44 PM
Sold Cellpro 10s pogoods Aircraft - Electric - Helis (FS/W) 0 Mar 29, 2013 12:39 PM
Discussion CellPro 10S Unstable Power and/or <10V DonA FMA Direct 12 Oct 17, 2010 06:45 PM
Has anyone else noticed their receiver becomes unstable in the cold ? Darn Servo ! Parkflyers 6 Feb 14, 2002 05:53 PM
