Old Oct 07, 2012, 04:36 PM
kidovate is offline
Find More Posts by kidovate
FPV and Robotics
Joined Oct 2011
Question
Brushless Motor Loose?
Hi,
I have a brushless motor (ritewing branded), and the shaft seems to be loose in the assembly (I.E. the shaft and the part that rotates around the coils). I can actually move the rotor laterally very slightly, as well as forward and back. It's causing a LOT of vibration.
What is causing this and how can I fix it?
Christian
kidovate is offline Find More Posts by kidovate
Old Oct 07, 2012, 08:52 PM
Dr Kiwi is offline
Find More Posts by Dr Kiwi
Dr Kiwi's Avatar
Chattanooga, Tennessee, United States
Joined May 2003
Sounds like sloppy bearings... and the fore and aft might be due to a missing spacer or circlip.
Dr Kiwi is offline Find More Posts by Dr Kiwi
Old Oct 07, 2012, 09:02 PM
Glacier Girl is offline
Find More Posts by Glacier Girl
Kamikaze Ace
Glacier Girl's Avatar
USA, FL, Lakeland
Joined Jan 2010
Couple of things. How is the shaft secured to prevent it from pulling through?
Does it have an E clip or something that looks like a wheel collar on it?
With either it sounds like you have to much play between the retainer and the back plate of the motor for the in/out movement. Something as simple as readjusting the wheel collar, or adding a small washer between the clip and back plate to correct. Or if you know what you are doing, you can press the shaft deeper into the the bell to take up the slack.
Side to side movement, could be a bad bearing allowing lateral slop. Feel any roughness when your turn the motor? If it's a bearing, It's possible to repair, you'll have to find a matching set, press out the old and press in the new. Another one that you need to know what you're doing or you'll just make it worse, if not destroy it.
Only other thing and I've seen it on some "frugal" motors. The bell is held to the shaft with a pair of set screws. And the clearance between the shaft and hole in the bell is a little too large. Not really a lot you can do there, other then drill and tap for two more set screws on opposite sides, or try and make a bushing.
Glacier Girl is offline Find More Posts by Glacier Girl
Old Oct 08, 2012, 04:23 PM
klique is offline
Find More Posts by klique
Mum is the word!
Joined Jun 2003
He had the C clip slide down the shaft , it never had the thrust collar put on to support the C clip.
All fixed now.
klique is offline Find More Posts by klique
Sold Turnigy 1811 Brushless Motor 2900kv & Phoenix-10 Brushless ESC hobbylink1 Aircraft - Electric - Micro & Indoor Airplanes (FS/W) 0 Aug 13, 2012 04:58 AM
Sold 4 brushless motors 18-11 2000kv Micro Brushless Outrunner (10g) kryptoknight Aircraft - Electric - Multirotor (FS/W) 0 Jul 23, 2012 08:39 PM
Wanted 2800kv Brushless Motor/30A Brushless ESC for Multiplex EasyStar upgrade davidjrojas Aircraft - Electric - Power Systems (FS/W) 1 Jun 25, 2012 12:33 PM
Wanted looing to trade brushless 1/8 buggy for plane keither1984 Aircraft - Fuel - Airplanes (FS/W) 0 Jul 18, 2011 01:05 PM
Discussion "Disgrace" must have been a loo-loo... arbilab Site Chat 28 Oct 10, 2010 12:07 AM
